Very quiet right speaker- do my valves need replacing?
24 replies [Last post]
nashie
nashie's picture
I have a Fatman iTube mk2 Carbon and it's been working very well for a few years.  Now though, the right speaker is very quiet.
I know it's not the speaker itself as I swapped them over.  So the next thought that occurs to me is whether it's a problem with the valves.
When valves need replacing, do they just completely break (and therefore give you no sound at all) or can they deteriorate over time?
Mr Beachams
Mr Beachams's picture
RE: Very quiet right speaker- do my valves need replacing?
have you tried swapping the valves over?
__________________
Shanling CD-T80, Jolida JD1501P Hybrid, Morel 602's (Hand built & modified)
   LESS IS MORE!
nashie
nashie's picture
I haven't and that's a good suggestion. I'll try that shortly.
Question- there are three valves- one at the front, and two at the back.  Do you know why there would be three?
acalex
acalex's picture
Is the front one smaller than the two at the back? The smaller is usually the preamp valve.
The answer is yes, if you lose balance probably the valves are to be replaced. Probably the big ones as the pre-amp valves (smaller) last much longer. How many years you had these valves? My final valves usually last between 3000 and 5000 hs whilst my pre valves almost twice that time...
nashie
nashie's picture
Well I've had it since 2009 and never changed the valves that came with it and I use it a lot so it's probably time to replace them.
The valve at the front is large, and the two behind are smaller. According to the spec they are 2 x 6N1 (ECC85) & 1 x 6E2 (EM87) valves.
I'll swap the valves over later and see what happens. I hope it's just the valves, I love this dock. Thanks for the advice guys!
chebby
chebby's picture
Online
Swap around the two smaller - ECC85 - valves.  The large one just acts as a peak level meter ('magic eye').  Actually it's just for show really. Pretty in the dark.
Make sure the amp has been powered off (and unplugged) for a while before doing this.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
nashie
nashie's picture
I've swapped the two smaller valves around and now the balance is fine. I really wasn't expecting that.  That's a bit confusing.
chebby
chebby's picture
Online
Possibly because unplugging/plugging them back in has 'wiped' the contact pins.
__________________
nashie
nashie's picture
While we're on the subject- can anyone recommend a place where I can buy replacement valves when the need arises?
Thanks for the help guys!
chebby
chebby's picture
Online
Calling/emailing the manufacturer could be your first stop. I'd be suprised if they couldn't sell you a couple of valves...
http://www.fat-man.co.uk/article.php/5/contact_us
__________________
acalex
acalex's picture
Contacting the manufacturer would be my choice also. If you can't get what you need just let me know, I have a friend who sells every type of valve and would be glad to ship to you.
daytona600
daytona600's picture
for valves try watford valves , probably based on a dared mp5
http://www.dared.com.hk/products_mp.html
eggontoast
eggontoast's picture
There are loads of online valve sites, try here http://www.tube-shop.com
__________________
Sonos > M-DAC, Beyerdynamic A1, FiiO E17/E9, HLLY DMK-IV, STAX Lambdas, Denon AH-D5000, Sennheiser HD-600, Beyerdynamic DT770, MCA customs - Magnum V4's, Sennheiser HD-265 linear, Sennheiser CX300-II.
floyd droid
floyd droid's picture
Chelmer Valves are pretty good. Here ya go. I've used them many times. Even if your valves dont show on their search, it dosnt mean they cant get them, so give em a call. They should be able to sort you out. Do not be tempted by 'bargains from China' on ebay. Been there done that , phut bang wallop is quite a regular outcome.
Hotrox .
World Tube Audio.
Tube Depot.
The Tubestore.
Loads of em out there, just get clicking  Smile
floyd droid
A link would be useful  Smile
acalex
acalex's picture
There is no link, it's a real shop in Antwerpen...the guy producing/repairing/modifying amplifiers who also sells tubes (included NOS).  Smile
