7 posts / 0 new
Last post
PG
PG's picture
Last seen: 3 years 4 months ago
Slightly muffled sound
I have got a rega Deck, artiston ax910 amp -15 years old, Philips 723 CD player - also old, and two sets of Bandw speakers with a QED box which means both sets of speakers  are connected to the amp and I can Switch from each set or have both on. The two sets of speakers are B and W dM600 s3 and 686's. The tv is also plugged into the amp.
I know the amp and CD player arn't great but the sound used to be ok. Reacently I have noticed the sound from both the cd and the turntable have become slightly muffled, a bit like an over played record, I have tried various records and CDs, old new etc but the same issue occurs, although I don't really notice it when watching and listening to the tv through the system.
Is this an issue with the Amp?   i.e. Is it blown or worn out? Or is it the speakers? can't imagine it is the  speakers It is never on very loud, I have had alook and they look alright. Any advice would be gratefully received. Thank you.
anis93's picture
Last seen: 5 months 1 week ago
RE: Slightly muffled sound
Hi , he could be the tweetwer, cover the tweeter with your hand and see if you can hear a difference.
Dougal1331's picture
Last seen: 1 year 9 months ago
I doubt you speakers are to blame- unless you've had a big party recently, tweeters generally just don't blow by themselves during sensible use.
My thinking would be that the output capacitors in the amplifier are on the way out- which is easy enough to diagnose and fix, but probably best done by a qualified repair person.
There's a chance it could be the capacitors in the speakers' crossover, but I would think that very unlikely as they are modern speakers.
Can you get your hands on a different amp to test?
chebby's picture
Last seen: 1 day 3 hours ago
I know the amp and CD player arn't great but the sound used to be ok. Reacently I have noticed the sound from both the cd and the turntable have become slightly muffled...
What about the sound from the TV?
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
PG
PG's picture
The sound from the tv seems ok, I wondered if it was because the audio from broadcasts is perhaps mor compressed or something and so it doesn't get effected by the fault
PG
PG's picture
Thanks Dougal,
I think that is what I will do this week.
PG
PG
PG's picture
Hi Anis
i will check out the tweeters
thanks
Log in to post comments
