10 posts / 0 new
Last post
martingo's picture
Last seen: 3 years 9 months ago
ProAc D40R
I have read the review of ProAc D40R - obviously great speakers. I am currently running ProAc D18 with Supernait and I am quite happy with them ( may be sometimes missing more bass). I am thinking if D40R are an option for speakers upgrade. My question is will Supernait be able to drive D40Rs enough well in order to get best out of them. Did somebody hear such a combo ?
MUSICRAFT's picture
Last seen: 3 days 17 hours ago
RE: ProAc D40R
Hi martingo
In all fairness i think D40/R's are likely to benefit from even higher quality of amplification eg. NAP 250 however (particularly if you're not after disco like listening levels) the Supernait should do a good job at driving D40/R's.
Btw, for a worthwhile upgrade over the D18's also consider D28's.
All the best
Rick @ Musicraft
Musicraft (Derby) - Specialist Hi-Fi/AV Dealer
My system - Naim Core > Hegel HD30 > Hegel P30 > JL Audio CR-1 > ATC SCM100ASL Professional Monitors > 2 x JL Audio E-112
Ketan Bharadia's picture
Last seen: 1 month 1 week ago
RE: ProAc D40R
I think you'll need something better than a Supernait to get the best out of the D40/Rs. It's not that they're particularly difficult to drive, more that they're immensely revealing and capable of huge dynamic swings when driven by something of suitable quality.
Ketan Bharadia
Technical Editor,  What Hi-Fi?
martingo's picture
RE: ProAc D40R
Thanks to both for the feedback. I see both of you with doubts about the ability of Supernait to get best of D40R ! And what about the new ProAc D30R ( which were just posted as specifications on their site). Will they be a better match with Supernait ? And also a good upgrade of D18 ?
ISAC69's picture
Last seen: 2 weeks 3 hours ago
RE: ProAc D40R
 Supernait power output of 80W is not enough for the D30R or D40R . You'll need a robust amp or monobloks to drive them .
As told above I think the D28 is a better option for you .
Hi Fi : Proac Studio 140MK2 / Mcintosh MC 152 / Mcintosh D 100 / Cambridge Audio CXC / YAMAHA BD -S677 / B&W P7 / Tellurium Q ,WireWorld,Audioquest & QED cables.
RE: ProAc D40R
I haven't heard the D30/R yet, but ProAc's track record is good. Getting the best from the D40/Rs is as much about amplifier quality as it is power output.
Ketan Bharadia
Singslinger's picture
Last seen: 1 year 4 months ago
RE: ProAc D40R
The Supernait will be able to do an adequate job with either the 30R or 40R but IMO it won't be a very good match. I've found that ProAc speakers with ribbon tweeters work well with pure class A amplification, perhaps the Sugden Masterclass integrated or the MF AMS 35i at the very least.
If however, you would rather keep the Naim but still go for a higher ProAc model, then perhaps the D40 without the ribbon might be better.
iceman16's picture
Last seen: 6 days 21 hours ago
RE: ProAc D40R RE: ProAc D40R
[quote=Singslinger]The Supernait will be able to do an adequate job with either the 30R or 40R but IMO it won't be a very good match. I've found that ProAc speakers with ribbon tweeters work well with pure class A amplification, perhaps the Sugden Masterclass integrated or the MF AMS 35i at the very least. If however, you would rather keep the Naim but still go for a higher ProAc model, then perhaps the D40 without the ribbon might be better.[/quote
Hi Singslinger
Have you heard the D40R with the AMS 35i? They could be my next project in the future.
 Musical Fidelity AMS 35i / Focal 1028be / Electrocompaniet EMC 1UP / MIT AVt-MA, Matrix 12 / ViaBlue-X40+MS-hd/iego
Hi Singslinger
Hi iceman16, no I haven't heard that combination but I'm using Accuphase class A amps to drive my ProAc k6 speakers with excellent results, hence my guess that a class A amp of equivalent quality would work well with the 40R.
Hi Singslinger
Hi, no I haven't heard that combo but I use Accuphase class A amps with my ProAc K6 speakers with excellent results so I'm guessing that a class A amp of equivalent quality would work well with the 40R.
Log in to post comments
