24 posts / 0 new
Last post
tgreen's picture
Last seen: 3 years 4 months ago
Naim Unitiqute 2 vs Arcam A19/irDAC vs Sonos
Hi- I'm putting together a new home system to run audio from iTunes, Spotify, Apple TV, Mac mini etc and also boost the sound from my new W905 Sony tv. I've been to-ing and fro-ing on whether to add a Sonos playbar and Play3's to support my needs but think I prefer the idea of Naim UQ2 with KEF LS50's more as I reckon the sound and appearance will be better. There's lots of hype about pairing Arcam A19 and irDAC with the KEFs but wouldn't Naim be better? It's not the biggest room, so 30W per channel would be fine. The cost is similar too!
Any advice would be very gratefully received!
matthewpiano's picture
Last seen: 3 weeks 5 days ago
Your projected use of the
Your projected use of the system suggests to me that actives might provide the way forward. Probably a good idea to audition the AVI ADM9.1RSS as well as the two options you mention.
Rega RP3/Elys2/TT PSU- Denon DCD720ae - Pioneer A400  -  Wharfedale Diamond 220 - Atlas Equator 2.0 - Beyer DT-770PRO - Mission stands
chebby's picture
Last seen: 3 hours 38 min ago
RE: Your projected use of the
Or the OP's suggested UnitiQute 2 feeding the new AVI DM5 actives from it's pre-outs. (The DM5s are about the same price - or cheaper - than the KEF LS50s so are within budget.)
http://www.avihifi.co.uk/products.html#dm5
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
BigH's picture
Last seen: 23 hours 32 min ago
RE: Naim Unitiqute 2 vs Arcam A19/irDAC vs Sonos
The  KEF LS50s are good speakers buy IMHO they are fussy about amplification and room positioning. Also I did not find them very good at lower volumes. The AVI suggestion is worth trying if you can get to hear them.
Listen to the music, not the hifi.
tgreen's picture
Thanks all for the very quick responses. I have to admit that the speaker choice is largely driven by aesthetics- I absolutely love the look of the KEFs and think they would complement my new lounge quite well! (Probably the wrong audience for a statement like that!!). Will certainly audition those options though, thank you.
 But, the Naim (or equivalent) component is what's been troubling me. Would it be THAT much better than a Sonos with all the Play3's, Sub, etc? I'm asking a lot in terms of connectivity and don't see there being all that many solutions out there.
The_Lhc's picture
Last seen: 2 months 22 hours ago
The problem with the Playbar is it only has one input, so you'd have to connect all the other stuff to the TV and then take an optical output from the TV to the Playbar, which can problematic, depending on the type of TV you have.
I don't know what the NAIM is equipped with in terms of connections for all the other stuff.
davedotco's picture
Last seen: 1 week 11 hours ago
AVI active speakers driven by Naim electronics.......
Enough to give AJ apoplexy....... Wink
Actually looks like a really good call to me.... :cheer:
tgreen's picture
Does anyone know any decent looking active speakers though? My GF wouldn't let me have the AVI's in the new lounge! Needs to be more Bang & Olufsen than Bowers & Wilkins if you know what I mean (not in a budget sense!). Thanks again though guys, this is really helpful stuff.
BigH's picture
Depends what you mean by good looking, so you say LS50s are fine? So you want a piano black finish?
chebby's picture
Has she seen the LS50s?
davedotco's picture
How about these, can be had for just under £1k a pair.
Comes in gloss black or white, grills included. Quite hard to get to hear them though.
tgreen's picture
Ha! Yes, she's seen the LS50's... And quite likes the 'rose gold' aspect! Piano black is the way forward, so those floor standees might be a goer. What are they?
davedotco's picture
Sorry, wasn't trying to be cryptic, just forgot to say.
They are Adam Artist 6, a fully active design in a very slender column. Drive them off a Unitiqute 2 pre- outs for a simple solution
http://www.adam-audio.com/en/multimedia/products/artist-6/description
BigH's picture
I'm still not sure what you want, so Kef LS50s are OK but B&W CM1s are not?
tgreen's picture
Sorry, i think I might be being a bit cryptic too... Bog standard bookshelves won't cut it. Something befitting a new contemporary lounge will. My b&W comment was throw-away, they look quite nice.
Found an old thread from someone who bought the original Unitiqute and paired with KEF R100's and said they were amazing. On that logic the LS50's might be a good pairing after all!
ID.
ID.'s picture
Last seen: 1 week 20 hours ago
On that logic the Blades might be a good pairing after all (but I doubt it). I'd definitely want to audition the combination first because prefer more powerful amplification. I'd guess Arcam A19 at a minimum. Further up the Uniti range is probably better, but to be honest (and I may have just not blanked out on people suggesting Naim amplification) Naim doesn't seem to be suggested too often in the numerous "best match for LS50s" threads that seem to hit the forum at regular intervals.
I thought the LS50s were good at what they do, but they don't go deep enough for me. I'd want to add a sub. The Adam ARTist 6s are high up my audition list, but that's because I'm hitting a phase where I feel the need to explore active speaker options.
Apple Mini -> Pioneer U-05 -> Adam A7X
ATV -> NuForce Icon HDP -> Genelec 8020C
Sennheiser HD650, HD595; B&W P7; Audio Technica ATH-AD900X, ATH-A900X
Pages
Log in to post comments
