Digital interconnect
16 replies [Last post]
dudleyperkins
dudleyperkins's picture
For an interconnect between a cd player and DAC, or an amplifier with a built in DAC, which is the best, ( in terms of sound quality), a Toslink optical or an RCA digital ?
Baldrick1
Baldrick1's picture
RE: Digital interconnect
It depends on what you are connecting and what you are using to connect...as sound quality is subjective.  I have connected my SL-P333 to my RA-11 using both an optical & analogue cables and personally I find that the sound quality/musicality of classical & jazz are better via the analogue whilst for more 'pop' (excuse the term) the optical sounds better.  But that is just my set up.
Remember also that what you will be comparing is the DACs (the one onbaord the CD player vs. the external) and so in some respects the cable comparison is not really a fair one IMHO.
Personally what I would do is connect up both as I have done and then decide.  If yo do not want to spend the money then see if yo can borrow the interconnects yo are considering and audtion them before making up your mind.  I have kept both connected (as mentioned above).
EDIT: Apologies...misread the OP...please disregard this contribution as it is not relevant.
embarassed
embarassed
__________________
Rotel RA-11 | Technics SL-P333 | Rotel RT-11 | Technics SL-L1 | KEF Q300 | Grado SR80i | Atlas & QED interconnects
CnoEvil
CnoEvil's picture
I think the slight majority would say digital coax, but some do prefer optical.........but it's by no means an open and shut case.
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
MeanandGreen
MeanandGreen's picture
I was always under the impression that coaxial is sonically better than optical, though I personally haven't tried optical.
I doubt there can be much in it, it's an on or off signal with no variables. I think any differences would be all but in audible.
__________________
NAD C326BEE Amplifier, Sony CDP-XB930 CD Player, Pioneer PDR-509 CD Recorder, Arcam irDock with iPod Touch, B&W DM 601 S3 speakers, Jamo 20"Stands, Revolver Rack, QED cabling throughout, Sennheiser HD 518 & HD 565 Ovation Headphones, Beyerdynamic DTX-101iE ear buds.
fr0g
fr0g's picture
They should sound the same. But if I were to choose, I'd go optical as there is zero electrical connection, and potentially less inteference. But I can't say I have ever heard any difference.
__________________
“Out beyond ideas of wrong and  right, there is a field.
I'll meet you there."
stevebrock
stevebrock's picture
This is purely my experience!
I found optical a bit more analouge sounding and this is what I use to connect my Apollo R to my DAC
__________________
Synology DS212j > Rega DAC > Rega Brio R > Rega RS3
Rega RP6 / Exact / Groovetracer SubPlatter
Chord Chameleon Plus / Rumour 2
Panasonic TX-P50 GT50 > BDP110e > Yamaha RX-V 667 > Rega Vox > Rega RS1
busb
busb's picture
I have a 1m Chord Prodac between CDP & DAC but it hardly ever gets used. My TV's sound is through a 3m basic optical & my ATV via a 0.5m optical. Some say optical is better than coax over longer runs. Personally, I've heard no difference between the two.
I've occasionally connected my laptop to my DAC via USB that's unusable unless the laptop is not powered through its switch-mode PSU! This highlights why under certain circumstances that optical is best - galvanic isolation - a technique used in a lot of non-audio electronics to remove damaging earth currents.
__________________
"The optimist proclaims that we live in the best of all possible worlds - the pessimist fears this is true."
James Branch Cabell
_________________________________________________________
MAINApple TV2 & iTunes Match, CA Azur 751BD or Panasonic P42V20B into audiolab M-DAC, feeding a Primare A34.2 via XLRs, 2x 5m of Atlas Ascent 2 firing up Totem Arros.
ON THE HOOF: iPhone 4GS/Sennheiser MM450.
Another interest:
http://www.flickr.com/photos/busb/
jjbomber
jjbomber's picture
Hasn't anyone found the difference to be 'Night And Day'?  excellent!
Doesn't anyone want scientific proof?  excellent!
Benedict_Arnold
Benedict_Arnold's picture
In the pst it has been mooted that a co-axial (electrical) digital interconnect is best for short runs, e.g. from a CD to a DAC, etc., whereas a fibre-optic is better for longer runs.
The signal from a CD starts out as optical, and is then converted into electrical for the on-board DAC in a CD player.  For an electrical interconnect, this data stream just gets fed into the interconnect, off to the DAC for processing.  If you use a fibre-optic, the signal gets converted back into an optical signal inside the CD player / transport, then fed along the fibre-optic (with a potentially more "lossy" junction at either end), into the DAC, where it's converted back into an electrical signal for processing by the DAC.
So the electrical route:
CD (Optical) --> Electric Digital Cable ---> DAC
The optical route:
CD (optical) --> Electric Circuitry ---> Electrical to Optical Converter ---> Fibre Optic Cable ---> Optical to Electronic Converter ----> DAC
So with the optical route there's two extra conversion prcoesses involved, which MAY increase the risk of data error and jitter.
I also find electrical interconnects a bit more robust physically, so if you're in the habit of connecting and disconnecting stuff, an electrical interconnect might be better.
ON THE OTHER HAND:
For long runs, I prefer fibre-optics.  The cables are a lot cheaper, especially for long runs, mechanically more flexible and the sources, e.g. my satellite box, and the destination, e.g. my surround sound, aren't as crticial as my hifi listening.
Just my opinion, naturally.
kmlav
kmlav's picture
I find the coax to be the best , chord signature. I have tried optical but I did not think it was as good. A good hi fi shop should give you a demo of all your choices.
There are many that will say its just a big load of 0's and 1's so how could it make a differance but it does.
__________________
Cyrus Stream XP, Arcam AVR 400, Cyrus Pre DAC QX, 2 Cyrus X Power in mono, Apple TV, Kef R300, Kef R100, KEF R200c , Chord Carnival SilverScreen, Rel T2 with Chord Cobra Plus, Chord Signature interconects, Sky HD, Denon 2010 Blu-Ray.
In the Kitchen Cyrus Streamline, Monitor Audio R90HD on MA stands.
CnoEvil
CnoEvil's picture
The optical route:
ON THE OTHER HAND:
I have never seen it explained like that before..............so very enlightening
__________________
MajorFubar
MajorFubar's picture
Aha! That might be the case, but natively the signals are electrical not optical, and surely there's more chance of errors creeping in as the signal is converted too/from light than it has through the most bog-standard electrical cable.
Just threw that in there for the sake of discussion...
__________________
Main gear: Mac Mini > HRT Streamer II+ > Cyrus 2 + PSX  > Cyrus tuner > Mission 794
Also cluttering-up the place:
Thorens TD160 no cartridge; Technics SL-P777; Marantz CD63 mkII KI; Marantz PM66 KI; Nakamichi DR-1
Benedict_Arnold
Just to add, I'm more confident of a "good" electrical connection than a fibre-optic one as well.  And remember, there's one at each end of the interconnect, whichever way you go.
jcbrum
jcbrum's picture
I regard the thinking, so far, in this thread, to have been clouded.
The OP is re-stated above, and imo should be re-considered.
Firstly a digital data stream does not possess 'sound quality', - that is a quality which can only be applied to an analogue signal, ultimately used to convey a signal to a transducer such as loudspeakers or headphones and which human ears can audibly detect or appreciate.
You can't listen to digits, and digits don't have sound quality, since all digital data is merely a string of information which is no different in character whether it carries text, numerical information, video, or even computer program instructions.
The only time 'sound' is produced from digital data is at the converter stage (output) of a DAC, when a new analogue signal is generated from the data.  By then it is irrelevant how the digits arrived at the DAC, whether it be by ethernet, digital wireless stream, internet distribution, toslink cable, s/pdif co-ax (RCA), or whatever, as long as the digital stream is not corrupted.
JC
WinterRacer
WinterRacer's picture
Good post JC.  I think the question the OP is asking could be rephrased as "Which S/PDIF connection, out of toslink and Coaxial is more likely to introduce errors?".
IMHO, the answer is that for all practical purposes, cable introduced jitter just isn't  a problem*.  Use toslink if you can as it gives electrical isolation between components.
*It's another theoretical problem the hi-fi industry has used to sell expensive kit that solves a non-existent problem.
__________________
My System
jjbomber
jjbomber's picture
I knew someone would want scientific proof. Now I just need someone to say the difference is night and day.  excellent!
