35 posts / 0 new
Last post
toyota man's picture
Last seen: 3 months 5 days ago
Dedicated electrical supply
Hi all I am having a new kitchen fitted soon and I decided to save some money by installing a new ring main just for the kitchen so when I had the floor up I installed a dedicated radial  circuit 16amp supplying  a double socket for my amp and cd player I didn't know if this was going to make any difference well I can say without any doubt that it makes a big difference the sound is more 3D and is much clearer as if some one has taken a screen away from in front of the speakers its much better a low volumes I have been swapping between my new circuit and the original ring main and the difference is night and day and she who must be obeyed even commented on it thinking I had been out and bought something without telling her this was an inexpensive upgrade total cost not including my time which to me was free as I enjoyed doing it £40 ish as you can tell I am delighted with the end result  :grin: While I was installing these electrical circuits I also ran ethernet cables for my tv and av units as Ive upgraded my internet to upto 60Mb
Musical Fidelity M6500i, Musical Fidelity M6 CDP, Musical Fidelity Encore Connect, ATC SCM 40s, Cord Chameleon plus XLRs, Tellurium Q Black speaker cables.
SiUK's picture
Last seen: 5 months 2 weeks ago
RE: Dedicated electrical supply
This should be interesting! Cool
Good idea btw. I was going to do something similar when I had my floor up but didn't get around to it. Still on the cards though.
SiUK
I must say I nearley didn't bother I am so glad I did now Smile
letsavit2's picture
Last seen: 2 years 3 months ago
Now go buy some some expensive power leads to add to the end of that MK wire you just put in!
all banter aside this would be the only power supply mod I would ever consider, a radial circuit straight to a dedicated spur. Although you may well have a problem with your ring main, old wires, loose connections etc hence why you have noticed such a difference. Now you have me thinking as this is something that can be tested easy, ie just run the cable to a spur and back box above the floor before lifting any carpet, floor boards etc. Even cheaper and easier for some to try is to turn off every other appliance on that ring and see if that makes a difference.
A radial circuit = A new power cable straight from main board to its own socket for the non engineers among us.
CnoEvil's picture
Last seen: 5 days 2 hours ago
Good job.
IMO. It's probably the single most cost effective electrical upgrade that you can do.
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
andyjm's picture
Online
Last seen: 2 days 5 hours ago
While there is nothing wrong with running a separate radial link to the distribution board, it is not as if the distribution boad is a magically clean source of power if you have rf problems in the house.  Most likely to be clicks and pops when then fridge compressor starts, or the boiler igniter circuit cuts in, this noise will feedback to the distribution board bus bars and then propagate through all of the house wiring - separate spur or not.  Running a separate spur increases the "distance" from the noise source to your amp ( and hence attenuation), it does not remove it.
There are regulations which define the amount of EMI a device can produce.  Any decent amp should be able to cope with this.  If the fridge is objectionable, it is probably because the suppression cap has blown up or fallen off.
The 'veil has lifted' effect noted by the OP is unlikely to be due to rf effects, and equally unlikely to be fixed by installing a spur except in exceptional circumstances.
Edit: the easy way for the OP to tell if there is any real improvement is to try his amp at high volume with the source switched off on his new spur and compare it to his original socket.  If there is a noticeable increase in background noise on the original circuit, then his mod has done some good. Otherwise, if it is the same, the mod has made no difference.
DocG's picture
Online
Last seen: 1 day 3 hours ago
Can I pop in?
In our new house, every socket will have its own radial link to the distribution board. I thought that would be excellent for the hifi in particular, but I read somewhere that the ground (is that the correct term in English?) should be common for the whole hifi chain, in order to prevent ground loops.
Can anyone comment (in a clear but friendly way -- I know less than nothing on this subject :shifty: )? Should I use separate wall sockets for every device, or get a distribution block?
Bluesound Node2 -- DEQX HDP-3 -- 4 x Hypex NC-400 -- modded Magnepan MMGs
davedotco's picture
Last seen: 5 days 4 hours ago
DocG wrote:
Can I pop in?
No need to worry Doc, just get a couple of these.
One for analogue, one digital, job done.
DocG's picture
Online
davedotco wrote:
DocG wrote:
Can I pop in?
OK, Dave! Excellent!  :eek: :huh:
I know that a picture says more than a thousand words 'n all. But... what the hell is it? Is it from out of space? Does it come from the distant future? Where do I put them? Who sells this? At what price? What does it do?  Bad
floyd droid's picture
Last seen: 2 years 7 months ago
A mahoosive hole in your wallet , thats what that is.    You little tinker DaveD.  Mind you Doc, Dave went for the cheaper option.
davedotco's picture
I did?..... :?
Aye , you could have lobbed in a couple of Isotek Genesis. Either instead of or ( not sure if you can do this ) piggy backed them with your suggestion.
RobinKidderminster's picture
Last seen: 2 months 3 weeks ago
Nice Xbox? Pointless post tho? Zzzzzz.
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
davedotco's picture
It is an Isotec Super Titan. A 'high performance' mains filter and 'conditioner' with the capapility of supplying peak power surges in excess of 30,000 watts.
No half decent system should be without one, or two if, as you really should, you want to keep your digital and analogue components separate. About £5k a pop.
What I really wanted to suggest was this......
The PS Audio Power Plant Premier. A full on mains regenerator, actually cheaper than the Isotec devices above, but hard to find outside the USA.
SiUK's picture
it is an Isotek mains generator.. I believe about £12/13K a pop.
SiUK
davedotco's picture
siuk,
Actually it is 'only' a mains conditioner, a filter if you like. The full 'regenerator' is the PS Audio device pictured in a later thread.
Robin,
For your information I have actually used a much less expensive (<£1k) Isotec product and it worked extemely well.
It removed a significant layer of noise and 'grain' from a relatively inexpensive (budget hi-end) system I had just setup.
Pages
Log in to post comments
