11 posts / 0 new
Last post
monkeymayor's picture
Last seen: 3 years 1 month ago
Budget Amplifier
Hello,
i am looking to buy a new Amp to compliment my Rega Plana 2 and Mordaunt Short speakers.. i am thinking about the NAD C325BEE / Rotel RA 971 or if anyone has any suggestions i would love to hear.
I like a clear, natural sound, with clear precise bass.
any suggestions would be greatly recieved.
Kevin
bluedroog's picture
Last seen: 3 weeks 2 days ago
RE: Budget Amplifier
What sensitivity are your speakers? If reasonable consider something like a Mini-T, can be a little harsh and struggle with hard loads but given the right speakers if you like the precise sound can be untreatable value. Smart little package too.
Thanks. The speakers are Mordaunt shorts MS10's... 8 ohm impedence, 88db sensitivity... just took a look at the Mini T, i would like to add more inputs to the amp - ie, tuner / cd player, so the Mini T might not be suitable?
a91gti's picture
Lovely speakers, soooo many happy hours.
I found they ran well from a few amps but for your assumed budget I would try a large Yamaha, be it an av receiver or "hifi" amp.
stevebrock's picture
Last seen: 1 day 12 hours ago
Rotel RA971 MK2 - great budget amp!
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
Cypher's picture
Last seen: 4 months 2 weeks ago
Try a Denon PMA-520AE. Don't be fooled by the low price...........it sounds really, really good IMO.
thanks for these suggestions.. will investigate all.
Does anyone know of the NAD C325BEE, and have any thoughts on it?
thanks
Tibor's picture
Last seen: 4 months 4 weeks ago
 For clear, precise sound go for budget Rotel and  Marantz amps.
Nad 325 BEE is good with strong bass, but a touch less clear and precise than Marantz 600x series amps and budget Rotel amps.
Nad 320, 325, 326  BEE amps have a musical, dinamic sound with rounded of treble.
I would go for NAD 325 because of musicality
Arcam Diva A 65 plus,  Arcam Diva CD 73,  Quad 11L Classic speakers, Pioneer P 1 DAB + Q Acoustics 3020, , Denon TU 260 L II tuner
matthewpiano's picture
Last seen: 1 month 2 days ago
I used to have the C325BEE.  It is an engaging amp and should gel quite well with the MS10s.  Be aware it doesn't have a phono stage so you would need to use an external one for your Rega.
Rega RP3/Elys2/TT PSU- Denon DCD720ae - Denon PMA720ae - Dynaudio DM2/6 - Atlas Equator 2.0 - Beyer DT-770PRO - Mission stands
do you know what the difference is between the Rotel RA971 and the RA971 MK2? that might be a silly question, but...
thanks! you might have just saved me a lot of convenience
Log in to post comments
