23 posts / 0 new
Last post
Pete68's picture
Last seen: 3 years 6 months ago
ATC SCM19 or ATC SCM40
Hi
I am about to upgrade my speakers and have the choice between the ATC SCM19's or the ATC SCM40's. I was planning on getting bookshelf speakers due to the size of my room and also so that I could crank up the tunes a bit without shaking the house next door. However, I have the opportunity to get the 40's at a slightly reduced rate.
Anyone who has owned either or both and would like to share their experiences would be helping me out a great deal.
Cheers!
Macspur's picture
Last seen: 1 week 1 day ago
RE: ATC SCM19 or ATC SCM40
12Designs wrote:
Hi
Cheers!
What amp and source will you be using the ATC with?  The reason I ask is that and forgive me if you already know this.  Being a very neutral speaker, as I know to my cost,  having previously owned SCM40's, it takes careful matching with the other components.
Mac
Electrocompaniet EMC1UP, Audiolab M-DAC+, Sonos Connect, Accuphase E470, Harbeth SHL5 Plus, Auditorium 23 SC, HiFi Racks Podium Reference rack, matching LS stands.
Pete68's picture
I will be using an Arcam Alpha 9 integrated and 9P power amplifier, and a Arcam Alpha 9 CD player. The integrated amp and CD player have both been heavily modified and the power amp has had a few mods as well.
hoopsontoast's picture
Last seen: 1 year 8 months ago
Out of the two, all things being equal, I would chose the 19 over the 40 every time. Much better integration between the drivers, great bass dynamics and slam. Just sounded better overall to me, for the price of the 40 I would look at an audition of the 20SL for not a massive amount more.
I would certainly demo before you buy though,
Michell Gyrodec SE / RB300 / 2M Blue | Sony DVP-S9000ES | Bryston B60 | Tannoy Stirling HE
Decware Zen | Keesonic Kolt | Rega R9
toyota man's picture
Last seen: 1 month 3 weeks ago
12Designs wrote:
Hi
Cheers!
I find that the scm40s deliver fantastic well intergreated sound from even low volume setting right up to mind blowing levels its always a good idea to make sure that the people next door and next door to them are out when you play  as you will not hear them knocking to ask you to turn it down what sort of music and how big is your room my listening room is about 3 x 4 meters  you will have no problems with placment as you proberbley know that there infinate baffle see if you can get a home dem good luck whichever you chose
Musical Fidelity M6500i, Musical Fidelity M6 CDP, Musical Fidelity Encore Connect, ATC SCM 40s, Cord Chameleon plus XLRs, Tellurium Q Black speaker cables.
davidf's picture
Last seen: 2 days 16 hours ago
12Designs wrote:
Hi
What speakers are you currently using?
While the SCM40 has an advantage being a three-way design, it doesn't use the higher quality SL driver that the SCM19's do, which is used in ATC's higher quality passive and active models.
I personally prefer the SCM19's over the SCM40's - they're such different speakers that they seem to divide opinion. As already mentioned, the SCM40's do require much more careful partnering. Do get a demo of them with your existing amplification if you intend on sticking with them.
The Little Audio Company
audioquest / audio technica / bluesound / chord co / cornered audio / golden ear / harman / innuos / jbl / kef / moon / ophidian / primare / revel / svs
Pete68's picture
Thanks for sharing your thoughts. I will be upgrading from a pair of Acoustic Energy AE120's
davidf's picture
While you may well end up with a pair of better quality speakers, you have to be careful that you stay within your amplifier's capabilities.
Pete68's picture
This is my one concern, that the Arcam 9 & 9P are not up to the task.
Although I have no doubt that the modified CD player can play well at this new price point the current amplification may have to be upgraded.
Any thoughts or recommendation for future reference?
davidf's picture
I'd see how the Alpha 9's fair first. If an amplifier is in full control of a speaker, it'll sound tight and punchy, with no loose or sloppy bass.
MUSICRAFT's picture
Last seen: 6 days 2 hours ago
Hi 12Designs
As superb as ATC's SLMT mid/bass driive unit used in SCM19 monitors is however all things being equal SCM40 monitors outperform SCM19 monitors by a big margin in practically every area below HF. The main reason for this performance advantage is down to the SCM40's incorporating ATC's legenday state of the art original studio Soft Dome mid range drive unit. I feel that Toyota man has fairly highlighted some of the qualities of SCM40 monitors earlier in this thread. Fwiw, since 2006 ( after auditioning) I have yet to have a client choose SCM19's over SCM40's. Imo, SCM40 monitors are probably the finest VFM passive speakers currently available on the market regardless of price.
Anyway, ultimately though SCM40 monitors will benefit from higher quality of amplification (such as a Plinius Hautonga, Naim NAC 202/Hi CAP/ NAPSC/NAP 250, ATC SIA2-150 MK2) however in the mean time your Aplha 9 & 9P (particularly if used bi amplification configuration) are more than capable of being powering SCM40 monitors. If you're happy to consider used/discontinued amplification then ATC's SIA2-150 MK1 is worth bearing in mind as an SIA2-150 MK1 will also provide a worthwhile upgrade in quantity and quality of power and performance. Btw, I just want to be clear in that Musicraft does not deal in used components.
ATC studio Soft Dome monitoring. The sound of accuracy.
All the best
Rick @ Musicraft
Musicraft (Derby) - Specialist Hi-Fi, AV & Multimedia dealer
Pete68's picture
Rick, thanks for this helpful information, just what I was looking for. I will get the 40's and see how things pan out with the Arcams for now. I have been looking at upgrading the amp, especially to a Lavardin but your suggestions have thrown some new options into the mix. Food for thought. Thanks again.
plastic penguin's picture
Last seen: 3 days 19 hours ago
Why have you limited yourself to ATCs. Nothing wrong with them but there are other equally worthy speakers, especially as you're in transition with the amp.
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
MUSICRAFT's picture
Hi 12Designs
Your welcome.
All the best
Rick @ Musicraft
Macspur's picture
As superb as Lavardin amps are, I'm not sure they would drive the 40's well enough.
Mac
Pete68's picture
I am actually getting the ATC 40's as a part of a business deal and probably wouldn't have chosen them otherwise. I will have a listen to them but have a sneaky feeling that I will sell them on quite quickly for a few reasons. 1. I have a reasonably small place. 2 I have older amps that probably won't get the best out of the ATC's and 3. I was planning to move on from floor standers to bookshelf speakers. I could get the 19's but the resale value on the 40's is greater which gets me closer to what I actually would like (Triangle Duetto SW2). Although I haven't yet heard the ATC's I am not personally in to the clinical, monitor sound. Maybe I will be surprised, who knows...
Anyway. No home demo so I will have to see how I find them when I get them.
Pages
Log in to post comments
