Mini AV Reciever
3 replies [Last post]
Nick2ooo
Nick2ooo's picture
Hello,
I would like to purchase a new AV reciever for my room.
My current set up consists of my PC, Sky Box and Xbox all plugged into my TV.
My TV is a Samsung UE32ES6710 and has been reported to have problems with the Audio Output. Therefore I would like to purchase a small AV Receiver with maybe 2-3 HDMI
Can Anyone recommened a good AV reciever which does not take up too much room and comes with atleast 2 HDMI input ports and 1 HDMI Output?
Many thanks!
bigboss
bigboss's picture
RE: Mini AV Reciever
__________________
Nick2ooo
Nick2ooo's picture
bigboss wrote:
What's your budget, & which speakers are you planning to use? Check these: http://www.marantz.co.uk/uk/Products/Pages/ProductDetails.aspx?CatId=Hom... http://www.marantz.co.uk/uk/Products/Pages/ProductDetails.aspx?CatId=Hom... http://www.amazon.co.uk/Harman-Kardon-BDS-570BQ-230-B2/dp/B0067YFQO8/ref... http://www.ebay.co.uk/itm/Denon-S5BD-Cara-5-1-Bluray-Home-Theatre-Receiver-/330803402292?pt=UK_AudioTVElectronics_Video_DVDPlayers_Recorders&hash=item4d056b5634
Hello,
Many thanks for your reply. I have been on holiday for the last few days and didn't get the chance to respond.
I am not sure which speakers I am going with yet, although I have decided I would like to go with a 2.1 system (or sound bar) as oppose to a 5.1 surrond system. This is mainly because my PC is set up in the corner of my room and I don't really want speakers spaced out in each corner.
Some of the AV recievers you suggested do look pretty awesome and I may end up going with one of them. However, if I am only using a 2.1 system, is there anything smaller you could suggest with 2-3 HDMI ports? Maybe also slightly cheaper! Smile
I currently have the following set up downstairs:
5.1 Q Acoustics 2000 Speakers
Onkyo TX-SR608 Amp
Cambridge Audio Azur 650BD
LG42LH5000 TV
So for the best movies in 1080p, I would normally go downstairs to watch.
Thanks for your time, any input would be great.
alimcd
alimcd's picture
If it is just for a bedroom and there is an existing system downstairs why look at recievers at all?
For example:
Yamaha YHTS401, Fairly discrete, all the inputs that you would need and expandable to 5.1 if needed.
Q acoustics Qtv, a bit of an odd-ball, but if you can find one they are a great and almost invisble upgrade to TV audio. (we did them c.£300 but they have been battered by the internet(not saying where I work))
Denon DM39, they stuck an optical socket on the back, grab a decent set of standmounts (mercury V1/BX2) and use the Digital output on the TV.
Marantz MCR603, Can't explain how good this little guy is, again use the digi out of your Samsung and partner up with a solid set of stand mounts. If you put the '603 into it's Bi-amp configuration I would definitely recommend the Monitor Audio BX2's or Q 2020's as you will be familiar to how they sound.
Finally (and my own personal solution for my bedroom) The Teac AH01, brilliant DAC, great amp and I beleive the only of the mentioned products that uses a toroidal transformer. Runs an old set of B+W 603 s2's fine despite its fairly modest 25w output.
Hope these are food for thought.
Ali
__________________
Living room: Sony STRDA2400ES preamp, C/A 640R power amp, Mezzo 6/5/2, Monitor Audio BRFX, LG 47LD920, Xbox 360, Virgin HD, Panasonic DMPBDT120, ZP90.
Headfi: Linn Basik/2M red C/A 640P, Zebrano Grado Sr80i's, Walnut 125's and 80's, Teac UDH-01, Pro-ject Headbox2, Fiio E9.
