Marantz sr 5006 PLEASE HELP!!!
I'm just in the process of setting up my Marantz sr5006. with dali fazon 5.1 3's
when I use the set up wizard along with the audessy microphone No sound is emitted.
it is detecting the speakers but no sound.
The volume control seems to be linking from the amp to speakers because i can hear the interference getting louder and quieter.
Ive checked the connections countless times, tested all the speakers one by one with my old stereo amp.
Needless to say, there is no sound from my sources even after setting them up manually, although the picture is coming through via the amp fine.
I'm pulling my hair out!!!!
PLEASE HELP!
I had similar with recent setup. Couldn't find anything wrong - cos nothing was wrong. Powering off and on again got it working
Just tried it.
THATS IT!!
Thanks Mark, I'm glad it was something simple/me being stupid
Glad to be of help.
Hello, I do not see how to post a new forum, so I am asking a new question here. The Set Up Wizzard directs me to press "Enter" to start set up via remote control. Nothing happens when I press enter. I have turned equipment on and off serveral times, without luck.
Are you sure you have got speakers A switched on, you can toggle between a, b or both with the A/B button on the remote.
Panasonic 50GT30B | Marantz SR5006 | Boston Acoustics A26 front - A225C - A26 rear | Panasonic BDT310 | Sky+ 1TB HD | Virgin TiVo | iPad 2 | Samsung Galaxy SIII | New Apple TV | Control: Roomie via iPad & iPhone | Xbox360
