19 posts / 0 new
Last post
admin's picture
Last seen: 21 hours 20 min ago
weak wifi signal due to router far away - help needed please!
BenLaw's picture
Last seen: 1 year 10 months ago
RE: weak wifi signal due to router far away - help
Homeplug.
I am the danger.
6th.replicant's picture
Last seen: 3 years 3 months ago
RE: weak wifi signal due to router far away...
If your ISP is BT, get one of these:
nads's picture
Last seen: 4 months 1 week ago
meh
run a wire.
bob.g's picture
Last seen: 2 years 5 months ago
RE: meh
Homeplug
nads wrote:
run a wire.
nads wrote:
run a wire.
:quest:
Anonymous's picture
RE: weak wifi signal due to router far away - help needed please
don't know why this didn't work
Our sky router is in the kitchen connected to the ps3 and we use a laptop and ipad in the lounge which is approx 30 feet away but we have a very weak connection, particularly on the ipad.
When we take the laptop or ipad nearer the router they work fine.
What can i get to boost the signal in the lounge?
I had a look on ebay and found these:
http://www.ebay.co.uk/itm/150Mbps-WIRELESS-N-USB-ADAPTER-LAN-NETWORK-WiF...
but maybe barking up the wrong tree??
the laptop has wifi built in.
Paul.'s picture
Last seen: 1 week 3 days ago
RE: meh
If your feeling Blue Peter you could build a parabolic reflector out of card and tinfoil Smile
BIGBERNARDBRESSLAW's picture
Last seen: 6 months 3 weeks ago
Panasonic TX-P50GT50 / Yamaha RX-A2020 / Panasonic DMP-BDT110 / Dali Zensor 3 / Dali Zensor Vokal / Mordaunt Short MS20i Pearl Edition / Cambridge Audio Minx 11 / Tannoy TS2.10 / Roksan Radius 5.2 / Ortofon Super OM 20
Anonymous's picture
i'm about as un blue peter as they come!
isn't there anything to plug into the laptop i can use?
i've already got homeplugs connected to the lounge tv for sky anytime +
Anonymous's picture
BIGBERNARDBRESSLAW wrote:
http://www.amazon.co.uk/TP-Link-TL-PA211KIT-200Mbps-Powerline-Ethernet/dp/B004INVKP4/ref=sr_1_1?ie=UTF8&qid=1335903793&sr=8-1
As suggested by others.
these are the ones i've already got funnily enough as mentioned above
maybe i should get a single one then and connect it to the laptop and run off the router like the sky anytime plus does?
Anonymous's picture
what about the weak ipad wifi signal??
rs6mra's picture
Last seen: 1 month 5 days ago
How old is your router? If its a wireless g router then that is possibly one reason as to why your signal is weak. Another is if you have thick walls.
You could try increasing the height of the router.................... :grin: it does work though!
A Wireless N router is much much better and its indoor & outdoor range is supposed to be x2 that of wireless g.
Your iPad runs off wireless N and so having it hook up to a wireless N router would make for a much better connection. If changing to a N doesn't solve the problem then you may need a wireless access point. Such as: http://www.buffalo-technology.com/en/airstation-nfiniti-highpower-giga-wireless-n-router-access-point.html
Anonymous's picture
think its about 3-4 years old so not sure what type it is.
maybe i'll call sky and see if they do a better router first.
appreciate all the ideas
Anonymous's picture
so homeplugs should sort out the issue with the laptop, but how do i boost the ipad wifi signal??
daveh75's picture
Last seen: 5 days 40 min ago
RE: RE:
If you have a spare wierless router kicking about (or buy one s/h from ebay, you can pick 'em up for peanuts) use it as an Access Point...
Pages
Log in to post comments
