samsung UE40D6100 TV picture judder
5 replies [Last post]
steakers
steakers's picture
ive been getting some recent odd things happening with this i cant work out if its sky or my tv although watching blu ray or net flix i dont get the judder ,
its like the camera is jerking for about two or three seconds then stops,
also ive had the tv for a while where would i find the firmware update the one on samsungs site isnt working .
__________________
SONY  STR DH810 amp /SAMSUNG 40UE6100 3D TV "LED BACKLIT/ SONY STR810  amp /  x box 360/ .Panasonic DMP-BDT220 blu ray player/  Q Acoustics 2000i 5.1 speaker package.
chris1011981
chris1011981's picture
RE: samsung UE40D6100 TV picture judder
Hi there i had the same tv the samsung ue40d6100 and had the same problems playing games was horrendous sometimes the picture would judder on pes 2012 etc when u kicked the ball it would judder for 2-3 seconds each time,
(updated the firmware to latest etc no help)
it did it on sky hd standard tv as well where the screen would pan then skip fast and then resume.
i wasted 600 pounds engineer came up said nothing wrong with it. i tried the settings etc nothing worked. had good quality hdmi cables 1.4 all settings for sky and xbox 360 where done properly
Superaintit
Superaintit's picture
I would look at tuning down the picture processing settings. For my 40d6500 this has solved most of the issues I had with this.
I will post my settings as soon as I am at home again. You could also google for settings and try them out.
Just make sure you note down what settings you had before the change.
Superaintit
My settings:
Menu PICTURE
Picture mode: Movie
Backlight 12
Contrast 76
Brightness 49
Sharpness 51
Colour 50
Tint (G/R) 50/50
Menu PICTURE>advanced settings:
Black tone: off
Dynamic contrast off
Shadow detail 0
Gamma 0
Motion Lighting: off
xvYCC off
LED motion plus off
Menu PICTURE>picture options:
Colour tone: standard
Digital moise filter auto
MPEG noise filter off
HDMI black level: normal
Film mode off
Motion plus: custom
Menu PICTURE>picture options>Motion plus:
Blur reduction 5
Judder reduction 4
seemorebtts
seemorebtts's picture
this is your motion on your tv.when useing your blu ray player it doesnt  judder because your blu ray is set at 24fames and when watching sky or xbox your tv is trying to put it into 40 frames or 60.and the the tv freaks out a little coz it cant handle it.should of got a sony.rock solid motion:)
__________________
chris1011981
Yeh i know i understand that now thing is 4 years ago i had the lg lh7000 100 hz full 1080p tv  and that never ever once juddered or went wrong so how can a company back then get it so right with a 300-400 pounds tv and 5 years on get it so wrong on a tv thats 600 pounds upwards ?
