RP6 and PM6004 phono stage
5 replies [Last post]
Jonesiani
Jonesiani's picture
Simple question really.
would the phono stage on my PM6004 be up to the job of being used with a Rega RP6? Or is a separate phono stage ideal?
Thanks!
respe
respe's picture
RE: RP6 and PM6004 phono stage
its not the deck that matters in this case, but the cartridge you will be using. The RP6 is capable of carrying some fab carts, that more than warrent a separate stage. So what cart will you be starting with.
jerry klinger
jerry klinger's picture
I agree and disagree. The deck does matter - the RP6 I have in my system is revealing a phenomenal amount of micro-detail previously unheard, and thus in itself warrants a top phono stage (which I have). Also, though, you're right that it can carry some super cartridges. I'm using a Dynavector DV20X2-L which I don't believe is OTT.
As to whether the PM6004 stage is good enough, I've not heard it but my instinct would be to say 'not quite'. Try borrowing the new Rega Fono from a dealer and see if it makes a difference.
__________________
Rega RP6/DV20X2L/Naim CD5XS/Flatcap XS/Naim NAT05XS/Pioneer N50/amp ??/Dynaudio 1.8-II
Paul@HiFi-Lounge
Paul@HiFi-Lounge's picture
I guess it comes down to how analytical you want to get, I'm sure that the Marantz will do an OK job and it will probbaly sound really nice, but I can't help feeling that adding at least a Rega Fono MM will add greatly to the presentation of the deck, the RP6 really is a great performer and I just don't think you will be maximising that with a built in phono stage of the Marantz, out of curiousity what cartridge will you be using, are you going with the Rega Exact?
__________________
HiFi Lounge (Bedfordshire)
Specialists in the brands that we are passionate about!
gregory
gregory's picture
That deck would deserve a better phono stage than what the Marantz can offer, however it will work and depending on what cartridge you will be using i'm sure you will enjoy it, but what is your budget and have you listened to the deck with your set up and or other components, a Dynavector phono stage is glorious with their cartridges.
ifor
ifor's picture
__________________
Source 1) "Inspired" Manticore Mantra turntable c/w Rega RB 301 arm, Goldring 1042 MM Cartridge, Graham Slee Reflex M phono stage, Graham Slee CuSat 50 interconnect
Source 2) Cyrus CD8 SE CD player
Source 3) iTunes (ALAC), iMac, Devolo Homeplugs, Apple TV3, Toslink, Arcam rDAC
Source 4) Technics SL-7 linear tracking turntable.
Roksan Kandy L3 amp, Spendor A5 speakers.
Other rooms: more Airport Expresses and Homeplugs with Denon AV system and Denon Mini system.
