24 posts / 0 new
Last post
jcarruthers's picture
Last seen: 2 years 10 months ago
Audio drop out
So I am getting this on my new turntable.
http://www.mintylamb.co.uk/upload/Memo.m4a
I get audio back briefly when I tap the stand the turntable is on.
RE: Audio drop out
Realising that not everyone probably wants to listen to an audio file, I'll describe it.
The audio goes muffled — so far this has generally been more towards the middle of the LP.
If I tap the turntable it comes back and then goes again.
The turntable is new, and I had to replace the cartridge as the one it came with was broken— it was seemingly straight forward to do this as there was no alignment due to the three holes of the Rega.
stevebrock's picture
Last seen: 2 days 15 hours ago
RE: Audio drop out
what is your bias set to?
obviulsy Rega recommend 1.75g with the Elys 2 start at 0 and see if it helps
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
chebby's picture
Last seen: 16 hours 6 min ago
RE: Audio drop out
That's not bias/anti skate.
It sounds like a dry solder joint somewhere in the signal path.
Back to the dealer as you say it's new.
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
RE: Audio drop out
Currently bias is set to 2.0g and tracking to 1.75g
chebby's picture
RE: Audio drop out
Well the bias is too high. Try it at half that value (or less) but I honestly think that recording you made points to something more serious.
If the TT is new then why not get the dealer to sort things out?
RE: Audio drop out
Sorry I didnt read OP post properly!
I seriously would take that RP3 back and ask for another!
Seems you have been very unlucky!
RE: Audio drop out
Thanks both — have contacted the dealer.
Overall a bit unhappy about my Rega turntable experience Sad
RE: Audio drop out
i must say i am not surprised!
mikeparker59's picture
Last seen: 8 months 1 week ago
RE: Audio drop out
Sounded like a dodgy connection to me. Be interesting to find out the outcome.
RE: Audio drop out
So the only connections are the ones at the back of the cartridge — and then somewhere between that and the cables that come out the back — so not too much to go wrong.
If I touch the wires at the back of the cartridge they make some noise out the speakers.
Testing it a bit more — it generally happens between tracks. The tracks will cut off really quickly as they fade out — and then it'll go wrong.
It only needs a light tap or two on the plinth and the sound comes back.
MajorFubar's picture
Last seen: 3 days 17 hours ago
RE: Audio drop out
Are you sure it's not the amp. I've said nowt up to now, but I'm not sure it's the turntable. Sounds more of an 'electronic' problem to me, which can only be at the amp-end seeing that your TT doesn't have built-in muting circuits (least I don't think it does).
Audio: MacMini / AEX > AVI DM10 + BK Gemini II sub; Visual: Samsung BD-C5500 > Panasonic TX-L47ET5B.
Head-fi: various, but most often Sennheiser HD-580 or RS-180
chebby's picture
RE: Audio drop out
Tapping the turntable support causes the sound to come back again.
If the fault is at the amplifier end, then tapping the turntable support should make no difference at all.
RE: Audio drop out
So apparently I have another dodgy cartridge.
Hmmpfff.
RE: Audio drop out
Hmmpfff.
This is not good!
What did your dealer say?
Anonymous's picture
RE: Audio drop out RE: Audio drop out
Hmmpfff.
Doesn't sound like the cart more a dodgy connection in the tt, I personally would take it back and ask for new tt
Pages
Log in to post comments
