Simply Italy - nice un?
5 replies [Last post]
NHL
NHL's picture
The power cube looked a little bit wobbly, how about the sound? Which transistor amp would be fair competition?
boohoo
altruistic.lemon
altruistic.lemon's picture
RE: Simply Italy - nice un?
The answer is not many. Needs speakers that are easy to drive, but.
shafesk
shafesk's picture
I think for that sort of price I'd recommend the Cayin a-55t or a-50. They've both got loads more power and they work well with a wider range of speakers. If you have a small to medium sized room, have a listen to the Cayin and Dynaudio 2/7...you can go all the way to the Excite series too and the amp can handle it. The build quality of the Cayins will put the Unison Research to shame
__________________
Hi-fi:
Denon DNP-720AE network streamer, Mordaunt Short Mezzo 6, Cayin A-55 T, Technics-SLQ210, Denon DP-29F turntable, 540p, Dac-magic, Marantz 5004CD and 6025 Turntable, Mac ,Pure AV interconnects, QED Revelation speaker cables, QED Performance interconnects.
Head-fi:
Akg K702, Grado SR60i, UE Triple-fi, Musical Fidelity X-cans, HRT Music Streamer 2+
hoopsontoast
hoopsontoast's picture
Looks a nice little amp, and good value for a SE EL34.
Plenty of choice for tube rolling in EL34's as well.
Heard nothing but good things about the Unison valve amps, and the one or two that I have heard have sounded very nice.
__________________
Sony DVP-S9000ES | DIY SET / Eagle SA100 | DIY Speakers / Eclipse TD-508 / Keesonic Kolt
NHL
NHL's picture
I could imagine that a DAC + tubes would be an ample sounding combination.
hoopsontoast
Hmmm where did my edit go??
Added around that price for the Simply Italy you can also get:
Audion Sterling (EL34 and KT88 ) SE amps new, great value.
http://www.audion.co.uk/poweramps/Sterling%20Mk1%20EL34%20integ.html
Radford STA-15, the best EL34 amp I have heard, would need a pre but its lovely!
Audionote Oto (EL84 PP) second hand, my choice for a valve integrated around that price, fast and supprising punch for 12wpc.
Ming Da MC368 (rubbish name) but brilliant value for the money:
http://www.bd-audio.co.uk/Ming-Da-MC368-B902.html
Plenty of Icon Audio models, not heard any of the integrateds though.
__________________
