Rega RP1 and Cambridge Audio 640A
Hello Fello Music Lovers,
I have recently received a Rega RP1 as a gift due to the large record collection gathering dust in my loft. I have tried plugging it into the phono of my Cambridge Audio 640A amp and have been met with silence. The TT has the performance pack fitted and I would appreciate any advice on where i am going wrong.
Thanks in advance to any fellow music lovers who can offer some advice
Mark.
Thanks Matthew,
I read that it is best not to use the phono input for a phono pre-amp. Do yo have any advice which channel to use on my 640A
Mark.
The 'Phono' label on the input is simply to aid identification - connect the RP1 to a phono stage, then the phono stage to the 'phono' rca inputs on the amp.
Thanks Numpty,
Quite daunting coming on here as i know next to nothing about setting up a turntable. Have been playing cd's for years but i'm chuffed to have a new turntable and want to set it up to the best standard possible.
Mark
The RP1 is a great turntable, especially with the performance pack. Get yourself a decent phono stage and you'll be enjoying great sound in no time.
Thanks again Matthew,
Will let you know how i get on. Thanks for taking the time to pass on your knowledge. Appreciate it.
Mark.
Rega's Fono Mini A2D (£85) is a really good phono stage too.
Thanks Ketan,
Having read the review in What Hi-Fi i have ordered the Rega pre phono. Hopefully this will help,
Mark.
Rega's Fono Mini A2D is now wired up and my turntable is sounding sweet as a nut. In fact much better than i anticipated. Very happy.
Thanks for the advice everyone
Mark.
- Login to post comments
The Cambridge 640A does not have a phono stage built in so you can't connect your Rega directly to it. You need to get a phono pre-amp to go between the turntable and one of the line level inputs on your amp. The Cambridge Audio ones are pretty good - see if you can find a second hand 640P. Alternatively the NAD PP2 is very good as well.
Rega RP3/Elys 2, Roksan K2 CDS, Squeezebox Touch, Denon PMA720AE, Q Acoustics 2020i, Sennhesier HD595, Beyer-Dynamic DT770PRO, Chord Crimson/Chord Rumour 2
