Rega Brio-R heat
11 replies [Last post]
jcarruthers
jcarruthers's picture
This weekend I finally got my new amp warmed up with some decent volume levels (for reference about 10 or 11 o'clock)
Playing via my V-Dac it sounded great— Premiers Symptomes blew me away — and OK Computer had stuff in the mix I had never heard before.
The amp sits in on a shelf with about an inch clearance above it — and it was decidedly hot after an extended listening session.
Hot as in "if I press my hands either side it gets uncomfortable after a few seconds"
I figure that the small chassis is going to get a fair bit warmer — but the power output is 50W so I was expecing it to stay cool based on my speakers being reasonably easy to drive (I presume they are)
So what is hot and what is warm for this amp?
James
__________________
Rega RP3 w/ Elys 2 | Rega DAC | Rega Brio-R | B&W 601 S3 | Grado SR60
Chord CrimsonPlus | Audioquest FLX/SLiP 14/4
Arcam rPAC | AKG K550
David@FrankHarvey
David@FrankHarvey's picture
RE: Rega Brio-R heat
If you imagine your volume control as a clock face, where was it for this extended listening session?
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
Ketan Bharadia
Ketan Bharadia's picture
I think it would be better for the Rega to have a bit more ventilation than you've given it. We've never got it that hot in our listening rooms, and that's not for a lack of trying.
__________________
Technical Editor, What Hi-Fi? Sound and Vision
jcarruthers
David  — 10 to 11 o'o'clock
I've moved the shelf down a bit so it has a fair bit more ventilation — a good few inches now. Not yet had a chance to listen to it properly again to assess heat.
i guess it was reasonably optimistic in that position.
The light cooking does seem to have done wonders for the sound - finally broken in.
__________________
David@FrankHarvey
Apologies, I've just seen that in your first post - skimming again... Smile
I wouldn't have thought that a shelf an inch above it would have had that drastic an effect on what the Brio-R is doing, seeing as it doesn't have any ventilation holes or grilles. I could understand it getting a little warmer, but not to the extent you describe based on the volume you're listening at. The B&W's do drop to 4ohms I believe, but it shouldn't be too much of an issue unless you were nearer 12 o'clock or further.
Give the new position a go and see how you get on.
__________________
jcarruthers
I didn't think it would make much difference either - certainly not hot at all at lower volumes in that position.
My father has a Cyrus amp that is kept in a drawer — cool as anything.
Won't be able to listen at decent levels until the weekend again — will report back.
__________________
kevinJ
kevinJ's picture
Those B&W speakers have a minimal impedance of 3ohms. If you were playing a little louder, it could be that the amp was struggling to keep up where the impedance drops, but that depends on how stable the amp is.
jcarruthers
I never realised they were difficult to drive.
How do you mean stable?
__________________
David@FrankHarvey
The ability to drive low impedances and remain composed, without heating up to unnatural levels. While the Brio-R won't be the best amp to drive a speaker that dips to 4ohms or less, it shouldn't have too much of a problem, especially if it isn't being used above the 11 o'clock mark. If you have something to read the amplifier's temperature, you could then check with Rega to see if this is within its normal operating temperature.
__________________
Hi-FiOutlaw
Hi-FiOutlaw's picture
My Dyns are at 4 ohms, and some times I've sessions at 12 o'clock for 1 or 2 hours and my Brio R never pass from warm.
__________________
LivingRoom
Rega RP3 / Goldring 1012gx # Synology DS213 > QED Performance USB > Rega DAC > QED Performance RCA > Rega Brio R > Supra Classic 2x4mm > Dynaudio Excite X12 and some times BK XLS200 MK II
BedRoom
SBT > G&BL teflon line RCA > NAD 3020i > Supra Classic 2x4mm > Monitor Audio RS1
jcarruthers
I was too lazy to get my IR laser guided temp gun Smile
A surprisingly handy gadget that has a new hifi usage it seems.
Will keep it on hand for next time.
I leave my amp on all day - just had a feel and it's most certainly warm considering the volume is turned down and it's not playing anything.
__________________
p_m_brown
p_m_brown's picture
I'm no expert regarding operating temps but my old Nad used to heat up after a good listening session and my newer Arcam does too. As long as there is space for your kit to breath, you should be fine!
__________________
Digital - Synology 212j Nas, Sonos Connect, Leema Elements Dac, Chord Prodac
Analogue - Project Debut TT, Arcam A28, Kef R100, Chord Chameleon & Rumour
