PC to Hi-Fi
Hi I have always kept
my computers separate from my hi-fi but to future proof my quality music
listening I need some advice as how best to connect my PC with my hi-fi. Systems are;-
Hi-Fi;- Marantz PM6004 Amp & CD6004 & Q Acoustics
2050i speakers etc.
PC . Home assembled
Novatech ,AMD Phenom Quad processor, with 4GB RAM, 2TB hard drive, onboard
sound with Windows 7. 8 MEG + Broadband
I can get a quality Soundblaster sound card for £50 from
Maplin. This is PCI Express which is the only slot I have left. Can I connect
this to the PM6004 tape in inputs? All analogue.
I presumable cannot connect a USB lead from my PC direct to
the USB in on the CD6004.
Do I have to buy an audio steamer whatever that is?
My idea is that I download Jazz & Classical from
dedicated websites. Store the files on the hard Drive. Make back ups on CD on
the PC in case of HD failure and transfer this music to the hi-fi by one of the
various methods. What can I do and which route gives the best sound?
No not necessarily (The NA7004 that is). Your Pc is already a streamer and you don't need to buy another.
You should be able to plug your Pc into your CD player if it has a USB input. If for some reason this is not workable, you could get a perfectly good USB DAC for around £100 or less. Both of the below are very good DACs
Behringer UCA 222 <£30 REVIEW
You will need some way to catalogue and order your music and a software media player idealy, if taking the DAC route and feeding your amp from the DAC. If plugging into your CD player, it's own internal DAC will be used and you may be able to navigate through your music without a media player, but I have no experience with the Marantz equipment mentioned, so I'm just guessing here.
I use iTunes as a media player and to catalogue/organise my files, all of which are CD rips. My system is a computer based streaming one and works very well, being compact and very versatile. You already have the equipment to do the same, but a dedicated DAC could possibly be of some benefit, depending on the ability to use the CD player as a DAC or not.
Bluetooth is an option.Thats what I use
I Suppose I need a Marantz NA 7004, (don't tell the wife!)
