6 posts / 0 new
Last post
admin's picture
Last seen: 18 hours 42 min ago
Mains cables/ conditioners
 I am just wondering if its worth upgrading the standard power leads I got with my Cyrus equipment. I have the CD8vs and  8vs amp .2 x smart power plus's & 2 x psx-r power regulators.
 My question really is, with having the Psx -r's in the system I am assuming they "clean" the power supply to the Amp & CD so would better power leads or/and a conditioner be worthwhile ?
 any thoughts would be appreciated.
Anonymous's picture
Re: Mains cables/ conditioners
There are several posts in the Accessories forum on mains cables so have a look there. Mains cables cannot clean up the mains signal. You could look at a mains conditioner/filter but your power supply circuitry should already do a good job at this. Personally I struggle with the concept of replacement mains cables but many people claim to notice a difference so maybe pop down to your local hifi shop and have a listen to see if you feel it makes any difference. A good shop will probably loan you a cable so you can try it at home.
gregory's picture
Last seen: 2 weeks 4 hours ago
seperatre mains spur installed by a qualified electrician,cheaper than many power cords and conditioners.
Anonymous's picture
That's what I did,separate spur,I tried a few power cords,I think I would be kidding myself if I heard a difference,and even if I did,it wasn't worth the outlay.Try Russ andrews,True colours industries power cords as they allow you a 30 day trial,other wise it can be an expensive mistake.
I've never tried a mains conditioner,as I don't think I hear any problems,the only problems I hear are room acoustic ones,and that's where I prefer to place my money.
Thaiman's picture
Last seen: 2 years 10 months ago
I am very sceptic too, having bought a few so call high end ones.  The one that did work with my older system is Krystal Kables, not a well known name but I thought there was some improvment when I used it!
I got it for home trial and end up with one before I bought the Krell amp which refused to sound any different what ever power cables I was using.
Anonymous's picture
Thanks to you all, for your comments, seems to me that the general feeling is, I'd be better spending my money on other areas. I'll keep saving for new speakers instead !
Log in to post comments
