21 posts / 0 new
Last post
Jason36's picture
Last seen: 2 years 9 months ago
iPod connection to Marantz PM6003
At the moment I connect my iPod to my Marantz via the 3.5mm headphone socket into phono connections to the amp.
 Would I gain a discernable improvement in sound by buying the Russ Andrews GQ-24 Cable and connecting it via the socket at the bottom of the ipod into phono cables? Its an expensive cable at £64.00 if the sound difference is likely to be minimal.
All my music on the ipod is Apple Lossless.
Anonymous's picture
Re: iPod connection to Marantz PM6003
I've just changed from a 3.5mm connection to the dock port on the ipod.
It is alot better and it also overides the volume on the  ipod so that you don't have to turn it up as much, i just bought a cheap cable for about £7 and it works quite a bit better then what i had when it was plugged in the earphone jack.
Reason i went for a cheap cable was because i dont think its worth getting a expensive one as most of my music is in mp3 format from 224kbps-320kbps on my ipod and i much prefer to play cd's.
Jason36's picture
Thanks for the feedabck on that Smile
Any other views on this at all before I make a final decision?
Anonymous's picture
You could buy a cd6003 and connect to the onboard dac via the provided usb connector (bypassing the ipod's own dac).
Jason36's picture
Hi G force1
thanks for that, the plan is to actually upgrade to the CD6003 hopefully at the end of this month.....I wasnt actually aware that was how the USB port work on the Player (wasnt aware it would bypass the ipod DAC and utilise the onboard Marantz DAC)...does that mean that  can actually use the Apple cable provided with the iPod to connect to the CD player...I believe its a USB connection that plugs into the mains adapter for charging??
Or again would I be better of purchasing a Russ Andrews iPod to USB connector if the make one?
Anonymous's picture
I think that the standard connector would be just fine - after all it's just a usb cable.
As an alternative if you don't want a cd player you could purchase a standalone dac and a digital ipod dock. I think you could purchase these for roughly the same price as a cd6003.
mitch65's picture
Last seen: 5 months 1 day ago
Jason36:
Hi G force1
I'm pretty sure that the marantz's dac wouldn't be used to bypass the ipod internal one
Auralic Aries Mini - Marantz SA8005 - Marantz PM6005 - Little Dot Mk.II - Tannoy Revolution DC4T
Sennheiser HD540II - Musical Fidelity MF-200
Anonymous's picture
mitch65:
Care to back that up?
An easy test would be to check the digital out of the Marantz while playing from an ipod. I doubt that the cd player would take an analogue signal and digitalize it for the optical out.
csq2's picture
Last seen: 2 years 8 months ago
Trends Audio PA-10 is far superior than the GQ-24. Get the version with the ipod connection. Or get the Cambridge Audio iD50, which is better than the Arcam irDock.
Anonymous's picture
mitch65:
It's described as a 'digital input' on the Marantz website. Given that it is also compatible with usb memory sticks I would think that it does use the internal dac. This is inferred in the WHF review; maybe they could clarify this?
Anonymous's picture
csq2: Trends Audio PA-10 is far superior than the GQ-24. Get the version with the ipod connection. Or get the Cambridge Audio iD50, which is better than the Arcam irDock.
I have no knowledge of the Trends products, but the CA and Arcam docks are not digital; they do not offer a digital out to connect to a dac. These two units do;
http://www.whathifi.com/Review/Onkyo-ND-S1/
http://www.wadia.com/products/transports/170i/
Jason36's picture
CS2q - so how does that work the PA-10?
connect it via phono lead to an auxillary output on the Intergrated amp and then play the ipod through the PA-10 and Integrated amp?
csq2's picture
Jason36:
yep, connect it with some good stereo interconnects to an auxillary INPUT on your integrated amp. I found that using 3.5mm to RCA cable results in a very low volume from your ipod. I have to turn my amp to the 12 o'clock position to get some decent volume out of my speakers. I'm using a cheap 3.5mm to RCA cable and planning to get the PA-10 soon. The PA-10 will have plenty of juice to amplify the signal from your ipod.
mitch65's picture
rjes:
mitch65:
 OK, What hifi's review just mentions an ipod compatible USB connection which, to my understanding, is just like my Uniti's USB connection and this does not bypass the internal dac of any ipod. I think if the marantz could do this then they are missing a trick from a commercial point of view as this is a major selling point which is not being exploited.
Jason36's picture
csq2:
Jason36:
This does seem like a bit of an overkill though, because obviuously its not a digital output into the Marantz from the PA-10....so struggling to understand the gain I would get? I notice I can buy just the ipod to RCA phono lead that I could just plug directly into the Marantz and the bottom of my ipod....this would thereore bypass the internal iPod control.
However that then comes back to the original question of is the cable on its own better than the Russ Andrew QG-24 lead? ie worth the price difference.
Fisherking 145's picture
Last seen: 2 years 10 months ago
GQ-24 is a great cable, but if you're deffo getting a CD6003, I wouldn't bother getting one, just use the USB input on that. I posted about my findings on various iPod/iPhone connections to my receiver (Marantz) in answer to another forum members question, it shouldn't be hard to find, as I haven't posted too many times. However, if you're not getting the CD player, I would certainly recommend the Russ Andrews cable, even for that money.
Pages
Log in to post comments
