22 posts / 0 new
Last post
newtohifijkt's picture
Last seen: 1 year 4 months ago
Difference between Rotel RA 06 and RA 06SE
i just found out that thare are 2 types of RA 06. The standard RA 06 (which I have) and the SE version.
Anyone know the difference between the two? Mine is very good for rock musick but is unbearable with jazz and slow music especially those with female vocalist.
matthewpiano's picture
Last seen: 1 month 3 days ago
RE: Difference between Rotel RA 06 and RA 06SE
I'm surprised you have problems with jazz and female vocals on the Rotel.  I've found their amps to be pretty flexible across genres and recordings.  I wonder whether your QED speaker cable might not be helping matters.
Rotel amps don't change that much from one generation to another. Basically they don't need to as the basic Rotel design is a good one.  The SE upgrades across the range were subtle to say the least.  I certainly wouldn't go to any lengths to change from 06 to 06SE.
Rega RP3/Elys2/TT PSU- Denon DCD720ae - Denon PMA720ae - Dynaudio DM2/6 - Atlas Equator 2.0 - Beyer DT-770PRO - Mission stands
hhmmm.......
thanks for the suggestion. Will try to switch to thick copper cable then.
Previously I used NAD C320BEE + MA Bronze 2 with the same cable. Sweet, lovely sound, reasonable amount of bass........love the songs from Bocelli, Sade but for rock music,  i find it lacking......thus the change of amp and speaker. And the result, in my opinion, exactly the other way around.
want the best of both worlds. Still trying.......
Cypher's picture
Last seen: 4 months 3 weeks ago
It won't make any difference if you try copper cable  Wink
I would try a Marantz PM6004 or PM6005. You already have a CD6004 so it will work together very well.
If you need more power............see if you can get a Pearl Lite amp.......it's not that expensive anymore Wink
He already has a better amp than the Marantz 6004/6005. Wink
Those speakers do deserve even better though.  If the budget can stretch to something from Exposure or Creek then I'd get listening.  Otherwise a speaker cable change could give you a cost effective tweak.  Worth trying anyway.
PS What interconnects are you using?
Cypher's picture
Not better, just different. He doesn't like the Rotel sound with jazz so he should try something different I quess.
I am researching actually.  Any suggestion on amp? Budget would be around GBP 1000.
integrated or pre/power is welcome.
I can get audiolab 8200 pre power combo for around GBP 900.  or probably Rotel pre power (older version) for GBP 1,000. Are they suitable for my PMC?
for integrted, probably Roksan K2, NAD C355, Rotel RA1520.
i forgot the brand of the interconnect. Probably Daiyo Japan. Thick interconnect with OFC. Should I try something else? Any recommendation?
I'm going to recommend that you find a really good dealer.  Not a big chain, but a smaller independent.  Tell them what you currently have and give them as much info as possible about what you like and don't like about it.  Then entrust them with recommending a change to your system that will give you what you want.  Audition their recommendation and take it from there.  It worked for me after years of box swapping.
Beyond this I would be looking at amps from Exposure, Creek and Sugden (the Mystro should just be available in budget).  If you bring 2nd hand into the equation then there are the more expensive models from these brands (including the beautiful Creek Destiny 2) as well as the Arcam A38 - an amp that pairs very well with PMC.
MUSICRAFT's picture
Last seen: 1 day 23 hours ago
Hi newtohifijkt
Change the amp. Look out for a Rotel RA-1062.
Fwiw, we had a client visit us not long ago who is using a RA-10 and 685's. I mentioned the benefits of using an RA-1062 to him. He subsequently listened to an even older Rotel amplifier the RA-1060 (which the RA-1062 is based on). The RA-1060 outperformed the RA-10 (not surprising). He is now on the look out for the even higher performing RA-1062.
The RA-1062 is the finest and the most balanced sounding amplifier which Rotel have produced since 2003 Smile
Btw, for new amplification also consider Naim's Nait 5si.
All the best
Rick @ Musicraft
Musicraft (Derby) - Specialist Hi-Fi/AV Dealer
My system - Naim Core > Hegel HD30 > Hegel P30 > JL Audio CR-1 > ATC SCM100ASL Professional Monitors > 2 x JL Audio E-112
Thanks matthew.
will try to look at Creek or Exposure. Though preferably still something from Rotel as I live in Far East and would need to tow my PMC if I want to test various brands. I will check what my dealer (from whom I bought PMC) has.
in the mean time i will try to experiment with the speaker cable and interconnect
cheers
Hi Rick,
thanks for the advise. Will try to look for RA 1062 although I doubt I can get it here as it is an older model. But who knows.....will also try to look for 2nd hand.
What do you think about the following model?
- RA 1070
- RA 1520
- RA 1570
thanks in advance.....
edit - somehow....double post
You won't get any disagreement from me about sticking with Rotel.  Personally I think they are a superb manufacturer.  I still have an old RCD965BX CD player which can give my Roksan a very good run for the money.  Will never part with it.
plastic penguin's picture
Last seen: 15 hours 44 min ago
Rotel produce some really good stuff, but going back to the original question, there won't be (IMO) a significant difference between the 06 and 06SE.
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
Pages
Log in to post comments
