16 posts / 0 new
Last post
drummerman's picture
Online
Last seen: 3 days 4 hours ago
Cheap, good interconnects
In addition to the other mains cable thread where I recommend a 'cheap' mains lead, these are what I use mainly through my systems;
 http://www.amazon.co.uk/Profigold-Skyline-PROA4201-Stereo-Cables/dp/B003BUA394
I have also re-wired a couple of turntables with those. They are well construced with a decent amount of copper and good shielding. Well made too.
There is no large perceiveable difference between the Profigold and for example a QED Reference. I very much doubt anyone would manage to tell them apart.
Regards
audioaddict's picture
Last seen: 1 month 1 week ago
youre probably right drummer
TECHNICS SL1200MK2 ROKSAN KANDY BT amp and CD player Q ACOUSTIC CONCEPT 40 AUDIOQUEST FLX/SLIP 14/4  musical fidelity mf100
letsavit2's picture
Last seen: 2 years 3 months ago
Saved the ones you
Saved the ones you recommended in my favourites for the future. Fisual on ebay are also great value for money.
Inter_Voice's picture
Last seen: 2 years 2 months ago
Van Damme
Van Damme is another good choice.
mikeparker59's picture
Last seen: 9 months 1 week ago
I use these
I use these http://www.richersounds.com/product/hi-fi-interconnects/cambridge-audio/aud500-1m/camb-aud500-1m
perfectly adequate good quality connectors though a bit pricier than drummerman's recommendation. The connections are nice and firm unlike some 'throwaway' cables I've had supplied with equipment in the past.
Mattan's picture
Last seen: 4 months 2 days ago
RE: I use these
But you can get 4 sets of the Profigold for 1 set of the Cambridge Audio.  Are they that much better?
(BTW, I'm a long time user of CA's Pacific interconnects.  They've always seemed good quality for the price-point)
plastic penguin's picture
Last seen: 3 hours 44 min ago
Another good'un is Chord
Another good'un is Chord Chrysalis. A little long in the tooth but fabulous for the money.
Leema Pulse; Arcam CD73; PMC TB2i; Pro-ject Xpression with a ClearAudio cart; Denon TU260 MKII
RE: I use these
No idea I just say I use them.
the record spot's picture
Last seen: 1 year 10 months ago
RE: Another good'un is Chord
Just snagged one of the mains plugs DM mentioned and a pair of Fisual interconnects.  I liked the build of the Fisual coax so thought I'd give the RCAs a spin.
davedotco's picture
I use Fisual Pearl toslink and Super Pearl 2.5m analog.
About £30 all up. Seems nicely made and the fit of all plugs are solid without being over tight.
Thompsonuxb's picture
Last seen: 8 months 4 weeks ago
This weekend or maybe Monday
This weekend or maybe Monday I will make my own interrconnects -a pair of them consisting of an RG6 & an RG59 coax cable - I'll pass by Maplins and get some connectors.
I'll let you know how they sound....what!?....was that a group moan from the forum ...no, it must have been the bass from John Legends 'Lets Aim High' from his 'Love in the future' album....I hope.
RE: This weekend or maybe Monday
You fill yer boots pet....
jaxwired's picture
Last seen: 4 months 15 hours ago
RE: Cheap, good interconnects
I use a chord crimson.  Cheap and great.
Auralic Aries Mini -> Devialet 400 -> PMC Fact 12 -> Nordost Cables
Mattan's picture
Just found myself pressing 'buy' on those Profigold.  Always a sucker for a bargain
Cypher's picture
Last seen: 3 months 1 week ago
I also use a Profigold RCA cable (analog connection between DAC and amplifier). Works great and damn cheap  Wink
Online
Never used chord cables but I'm sure they're good and glad to hear that even a man with your expensive taste of equipment uses a well priced interconnect.
regards
PS. Try a set of the profigolds
Log in to post comments
