Bi-wiring
16 replies [Last post]
stevee1966
stevee1966's picture
Does bi-wiring make a big difference in sound quality over using a single cable, and does the facility of bi-wiring only comne with the more expensive amps.
I'm planning on getting a new amp and cd player but haven't got a huge budget so am considering the Marantz 6002, the Cambridge Audio Azur 540A, or Cambridge Audio 640A ?
I'm guessing that these are not bi-worable ?
Any advisde on this, thanks.
Andrew Everard
Andrew Everard's picture
Re: Bi-wiring
Any of those amps can be used to biwire suitable speakers - ie those with four terminals on the back, not two.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
d_a_n1979
d_a_n1979's picture
Re: Bi-wiring
Yup... As The 'Big A' said...
Using the 2 sets of speaker terminals on those ams, feed the HF terminals on the speakers with the top set of terminals on the amp and the LF terminals on the speakers with the lower set of terminals on the amp
Make sure that you remove the jumper bars on your speakers first though!
I usually work it as 'middle two sets of speaker wire to the top terminals' and the 'outer sets of speaker cable to the bottom terminals'.
Hope you follow!
Andrew Everard
Re: Bi-wiring
But you can just as easily do it with an amp only having one set of terminals, by connecting the two sets of wires for each speaker together at the amp end.
__________________
stevee1966
Re: Bi-wiring
Thanks for that info. So does bi-wiring give a greatly improved sound ?
I understand how the cable connects to the speakers, ie 4 terminals - 2 HF, 2 LF. Do these amps have equivalent terminals on them to connect other end of cable ?
Sorry for being a bit thick.
On another point - if a single cable is connected to a bi-wireable suitable speaker, which terminals should the cable be connected to - LF or HF ?
darrenwm1
darrenwm1's picture
Re: Bi-wiring
Steve,
Don't worry about it. Do not dismiss an amp or speaker because you think it can't be bi-wired.
Many see it as a marketing gimmick. Many companies only provide single wire terminals - for example, Dynaudio. Most recently Spendor seem to have reverted to it.
darrenwm1
darrenwm1's picture
Re: Bi-wiring
fr0g
fr0g's picture
Re: Bi-wiring
I did some extensive testing myself a while ago. I came to the conclusion that biwiring doesn't do very much apart from increase the effective thickness of the wire that you use. I found an improvement biwiring initially, but putting the speaker jumpers back whilst still biwired made absolutely zero difference. So I bought thicker cable and it now sounds the same.
Also dont let anyone tell you that replacing the jumpers with cable is the same as biwiring... Its utter nonsense. Whatever else it does, it certainly doesn't have the same effect as doubling the thickness (and resulting having of impedance etc).
Of course biamping is another thing entirely.
__________________
“Out beyond ideas of wrong and  right, there is a field.
I'll meet you there."
Anton90125
Anton90125's picture
Re: Bi-wiring
In my experience it does and a big one at that.
I also found you could tailor the sound by mixing cables, ie have one cable connecting the treble spur and another connecting the bass. For a long time I was using van den hull cs122 for the treble and QED C38 for the bass. This combo worked well for me on Rogers LS6's and Celestion SL600 speakers.
I would recomend you try bi wiring with a cheap set of cables and see if you can hear a difference between single/bi wired set ups. Get some one to blind test you if possible.
fr0g
fr0g's picture
Re: Bi-wiring
Try replacing the jumpers whilst still biwired and see if you see any change... Wink
__________________
Anton90125
Re: Bi-wiring
Yes, we did that test in the late 80's, (we didn't have jumpers as the speakers were modded in to biwired config so we used another small piece of C3cool. Yes there was a difference- different to single and different to bi wired. If I remember rightly, using the wired jumper caused the sound to loose some bass tightness and the stereo depth collapsed a bit, anyway to us it was inferior to biwiring using the same type of wire, which in turn of inferior to biwiring using different carefully chosen bit of wire.
JAXON5
JAXON5's picture
Re: Bi-wiring
Higher quality single run + quality jumper better sound than cheaper speaker wire bi-wired IME. Both better than single run alone.
Andrew Everard
Re: Bi-wiring
The changes are unlikely to be visible. Audible, maybe...
__________________
AudioSyok
AudioSyok's picture
Re: Bi-wiring
as far i'm concern.... everytime u buy a new speaker user manual will be provided...and i'm sure the manual will guide u on biwiring (or u can search online)
improvement? yes..... but not that much, anyway worth trying. and just to be clear, biwire is on the speaker and cable... any amp will do
JAXON5
JAXON5's picture
Re: Bi-wiring
I see what you mean that you may hear the change but is it possible to feel it??
Andrew Everard
Re: Bi-wiring
If you reach round behind the speaker, probably yes.
__________________
