151 posts / 0 new
Last post
techboy's picture
Last seen: 6 months 2 days ago
AVI ADM 9RS Mini Review
ADM AVI 9RS Mini Review
SETUP
ADM AVI 9RS on custom desktop stands
Surround and sub duty by Swan M50W 2.1
DAC / Preamp Setup 1 : Asus STX, Project Ember by Garage1217.com
DAC Setup 2 : AVI Built in DAC
OTHER SPEAKER SETUPS OWNED:
Aktimate Micro Asus STX Swan M50W Project Ember
Aktimate Mini+ Asus STX Swan M50W
Swan H5 Asus STX Swan M50W
OTHER HEADPHONE SETUPS OWNED:
Sennheiser HD 650 Project Ember Asus STX
Sennheiser HD 598 iPad 3 iPhone 4s
PLEASE NOTE
HD 650 has been properly amped by Project Ember which is an amp comparable to Schiit Lyr, Graham Slee, Lehmann BCL etc. I have also tried it with Beta22, so I know how HD 650 sounds.
I still believe that HD 650 are awesome headphones, just that AVI is a step up from them, while still a step below HD 800.
IMPRESSIONS
Initially, I was disappointed not having heard any speakers for the last few days except my Sennheiser HD 650 setup. But now that the speakers are slightly burned in, I am used to it and tried my HD 650 setup again, I can easily say that ADM AVI 9RS trumps my HD 650 setup. I don’t even want to compare it to Aktimates because they seem unlistenable after hearing to AVIs for a few days.
Don’t get me wrong, from a value for money perspective, Aktimates are still the best there is, but if you can afford ADM AVI then there isn’t much of a contest really.
After listening for a while on my AVIs I went back to my HD 598s and they sounded muddy and distorted in comparison. And they used to seem like heaven compared to my Aktimates. They were a huge step up from my Aktimates and now they are nearly unlistenable.
HD 650 is still much better than HD 598 now, which I didn’t appreciate as much earlier. HD 650 is comparable to AVIs but AVIs are better in many respects and often by a significant margin, so you can perhaps call them LCD2 territory. As AVIs aren’t as resolving of details as HD 800. I have listened to both HD 800 and LCDs properly amped.
MIDS
HD 650 and AVI both are mid centric setups. AVI has clearer mids by some margin I guess. However, HD 650 has thicker vocals. I would give this one to AVI.
LOWS
HD 650 has more bass, but AVI has tighter and sharper bass. Both are very good but again AVI is more audiophile like.
HIGHS
Both are very good, but AVI seems at least as good if not better.
TRANSIENTS
AVI is clearer and sharper here, HD 650 is more natural but sounds muddy in comparison.
IMAGING
AVI is better than anything I have heard before for stereo, including HD 650.
TRANSPARENCY
AVI is a step up. As transparent as it gets. Though I don’t find HD 650 veiled either with my amp, but AVI is just better.
SOUND STAGE
AVI is wider, deeper and taller.
CENTER STAGING
Not even a contest, AVI hands down.
LOW VOLUME LISTENING
AVI wins.
AVI is cleaner, clearer, more transparent though not sure whether it is more resolving or not, perhaps about equal, the two of them, not sure though.
HD 650 is excellent but AVI is just better but both are very listenable :)
HD 650 is better than cinema grade sound I would say, but AVI takes it a bit further with being more refined.
I have only tried with my Preamp so far.
With the inbuilt DAC (and not my preamp): It sounds slightly cleaner, but slightly less lively. Though the two are very close. However, without inbuilt DAC/without preamp, it doesn’t sound as good as I described it above, then it sounds a step below the above description.
And AVIs are not analytical at all, they are musical, perhaps not as much as HD 650, not sure about it, but definitely very musical and resolving, very transparent as well.
Thank You
Aakshey
PS:
Lows are not overpowering but are there nevertheless. It is mid centric. Lows are there but not emphasized.
Lows in AVI are tighter but well controlled and textured, not as powerful though.
Please Note
They don't sound like Aktimates at all. Aktimates have a wow effect which these dont on initial listen. Aktimates sound crisp and bright which gives that wow effect. These are opposites, a smooth resolving and transparent which isn't bright at all nor crisp but very love able once you listen for a few hrs. After that there is no going back to it. It is a super clean and transparent sound which makes Aktimates sound muddy in comparison, infact unlistenable once you get used to these.
I have updated the review. Lows on avi are tighter, check updated reply I gave you
It can. Because headphones usually have higher resolution and clarity. But not in this comparison.
I think I got the part about dynamics wrong, HD 650 is very dynamic as well, perhaps more so, not sure about that though.
In short, HD 650 and AVI ADM9RS are very close to each other in overall performance with AVI may be being a bit better overall, in several aspects that too. But both are very comparable.
HD 650 is definitely lusher, sweeter and more musical though. Though there are lots of place where AVIs are very close or better than them.
I prefer to listen to AVI over HD 650 unlike with Aktimates where I never listened to them and spent time only with HD 650
AVI ADM9RS is for 1.5 L. 9RSS is for more than 1.6+ L but not released in India yet. None of the current models come with a sub. The AVI sub is about 1L extra.
I got a discount which I won't disclose
Anybody in Delhi can audition at my place.
After more usage, their strengths and weaknesses are more evident.
If you want HD 650 (about equal, better in some ways, worse in others) in speaker form albeit with slightly lesser bass and slightly more neutral, then AVI ADM 9RS should be the obvious choice.
HD 650 are more musical, sweeter and lusher. AVI are more neutral (which I like actually), slightly cleaner, slightly more transparent. Imaging of both is very good. Centerstaging of AVI is definitely better. AVI is also less grainy. AVI is very refined and resolving for a speaker setup
Both are excellent and kings at their respective tasks  Having both together is much more than a dream come true
Thank You so much!
Aakshey
AVI ADM 9RS | HD 650 | HD 598 | Asus Essence One Muses Edition DAC & HA | Garage1217.com Project Ember HA | Asus STX DAC & HA | Fiio E12 | iPhone 5s | iPad Air | iPad Mini Retina | MacBook Air | Nexus 6 | PC (Realtec HD 898)
John Duncan's picture
Last seen: 2 months 2 weeks ago
RE: AVI ADM 9RS Mini Review
Wasn't it nice of Mr James to let you copy and paste that from his website. Did he ask you to?
Moderator: john.duncan.whf at gmail dot com
System burgeoning
spiny norman's picture
Last seen: 1 day 12 hours ago
They must have missed that bit when they were programming you with target data  ROFL
And so, on Feb 22nd 1966,...
techboy's picture
I didn't copy from anywhere. I have written this review. Check: akshaytalwar.blogspot.com
I have written the original review. Perhaps he copied it as a testimonial!
Anonymous's picture
[EDITED BY MODS AND SPAMMER BANNED]
Anonymous's picture
namefail's picture
Last seen: 5 months 3 weeks ago
Psst....you don't know where I can buy some gold for WoW do you?
EDITED for speeling
Ooo cool – a spam thread getting spammed!  :cheer:
techboy's picture
I don't give shit if you don't want to believe it, nobody paid me for this. This is what I genuinely felt. Though I have NOT heard others speakers in the 1000+ pound range. I went from Aktimates/Swan to these and also have experience with HD 650/HD 598. What I believe is what I care about. I don't give a damn whether somebody trusts me or not.
Thank You
Aakshey
techboy's picture
Please use copyscape.com to check who wrote it first. Then talk!
chebby's picture
Last seen: 3 hours 13 min ago
Thank You
Aakshey
Are you speaking as 'techboy' or 'usman127'?
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
techboy's picture
I have no idea who usman is. I am techboy. I have posted this review on several websites.
Chances are several people have also promoted and copied the review I wrote. The original is akshaytalwar.blogpost.com, I have also posted on HifiVision, HDD Audio and other websites.
There are lots of forum post copying websites which propagate and promote posts, maybe that is what I happened.
Thank You
Aakshey
chebby's picture
Within two minutes of each other on the same web forum.
techboy's picture
MY usual handle is techboy
My name is Aakshey Talwar.
My blog is akshaytalwar.blogspot.com.
I am present on lots of websites, example:
forums.anandtech.com aaksheytalwar
techenclave.com rite
hifivision.com techboy
erodov.com techboy
diyah name techboy
HDD audio name techboy
I am also on Facebook and Twitter @WeavingThoughts
Do you need any more proof? I can give my phone number and address as well.
If somebody wants, he can visit my place as well.
What do you want from me? Sad :S
Mod - Yes, lets leave that one shall we?  Both users have different iP addresses in different locations.
drummerman's picture
Online
Last seen: 1 day 6 hours ago
I thought it was/is an interesting review. Thank you.
Unusual to compare Headphones with a speaker system. I use headphones a lot and wouldn't even want to start to compare, the differences are just to obvious but needless to say, both have their place and time.
regards
matthewpiano's picture
Last seen: 1 month 1 day ago
As Drummer man says, it is very difficult to compare headphones and speakers.  Quite different tools IMO.
I think the best you can do is say how similar or different the overall characteristics are.  I've been looking for a speaker that has similar characteristics to my Beyer Dynamics for some time and I've finally found that in the Zensor 3s.  I wouldn't want to even start doing a thorough comparison though.  I like both.
Rega RP3/Elys2/TT PSU- Denon DCD720ae - Denon PMA720ae - Dynaudio DM2/6 - Atlas Equator 2.0 - Beyer DT-770PRO - Mission stands
Pages
Log in to post comments
