Klipsch claims Image S4 in-ear headphones offer improved noise isolation and value
The Image S4 in-ear headphones from Klipsch are the company's most affordable design to date, and use the same technology as its pricier models
So with that in mind, the company has just released its S4 in-ear headphones for £70, its most affordable pair to date.
The Image S4 uses Klipsch's oval ear tips that are designed to fit naturally in the contours of your ear canals, making them more comfortable for long-term wear.
This also means the ear tips provide better noise isolation, blocking out almost all ambient noise and helping them to deliver deeper bass.
In addition, the S4 is a moving coil design with controlled damping, allowing it to deliver a smooth, full-bodied sound, says Klipsch.
Finished in piano black with silver highlights, the Image S4 is supplied with three different-sized oval ear tips, an ear-tip cleaning tool and an aluminium case. A two-year warranty comes as standard.
You can buy them from selected Klipsch dealers or online from Klipsch direct or Amazon.
The latest hi-fi, home cinema and tech news, reviews, buying advice and deals, direct to your inbox.
What Hi-Fi?, founded in 1976, is the world's leading independent guide to buying and owning hi-fi and home entertainment products. Our comprehensive tests help you buy the very best for your money, with our advice sections giving you step-by-step information on how to get even more from your music and movies. Everything is tested by our dedicated team of in-house reviewers in our custom-built test rooms in London, Reading and Bath. Our coveted five-star rating and Awards are recognised all over the world as the ultimate seal of approval, so you can buy with absolute confidence.
