9 posts / 0 new
Last post
Charlie Jefferson's picture
Last seen: 8 months 1 week ago
Cheapest legal way to obtain second Sky HD box?
I currently have multi-room Sky, but one of the boxes is an old Sky non-HD box.
I need another Sky HD box for a second room, (having just binned a large CRT TV)  to hook up to a new TV.
I rang Sky and they said the cheapest option was a 2TB HD box for £149. Does anyone know of a cheaper legal option?
Thanks.
The_Lhc's picture
Last seen: 1 month 4 weeks ago
RE: Cheapest legal way to obtain second Sky HD box?
That's nonsense, Sky do a single tuner non-recording HD box which will be much less than that, you might even get it for nothing.
Thanks but forgot to say I need to be able to record too. I presumed all their boxes would have that feature as standard.
May have to bite the bullet then and fork out another £150 plus postage.
The_Lhc's picture
Oh well in that case yes, the 2TB box is the only one they offer now.
They do, apart from the one that doesn't, obviously.
Looks like it yes, I'm in a similar boat myself.
daveh75's picture
Last seen: 16 hours 9 min ago
Cheapest way will be s/h from the likes of ebay. Resellers charge the same or more than Sky.
daveh75's picture
Not quite.
They offer a standard box with 500GB drive, though confusingly they use the drx890 model no. Which used to be the 1.5TB model (now discontinued) and drx895 for the 2TB box
Forgive my ignorance, but how would I activate the box. I presume my viewing card from the old standard Sky box would be useless.
If I connected a second hand box to the Sky aerials (the dual connectors inside my living room) would I get a picture/signal?
daveh75's picture
You phone Sky and get them to re-pair your viewing card to the new box.
Quote:
IF i connected a second hand box to the Sky aerials (the dual connectors inside my living room) would I get a picture/signal?
Yes.
Though obviously you would need an active/paired viewing card in the box to receive encrypted/premium channels
I'm surprised Sky didn't offer you a free replacement for your SD box though tbh. Sky need shot of them due to s/w and security issues
bigboss's picture
Last seen: 5 days 21 hours ago
Why don't you ring them and say you want to leave Sky for Virgin / Youview? They'll give you the 2TB box for £49 or even free.
Log in to post comments
