High End Rip Vs Pc/Mac rips
29 replies [Last post]
staggerlee
staggerlee's picture
Hi - Was at the Bristol show yesterday and a lot of companies with high end ripping products were saying that riping by PC/mac's are of poor quality, data gets lost and hence buy a stand alone rip unit. other than marketing speak is there any truth in this. thsi sin't a question about file format as such, but just wondred whether this was the case ? Anyone using high end rippers
__________________
naim cd555, naim 552, naim 300, neat mf5's, sonos
fr0g
fr0g's picture
RE: High End Rip Vs Pc/Mac rips
If you are worried, apps such as EAC and dbPoweramp check against a database of previous rips (Accuraterip), this will show you if your rip is perfect or not.
The rips done a PC thus can be demonstrably proven to be "bit-perfect". There is no improvement on "bit-perfect" as it means that every piece of informatition on the CD has been copied exactly to the hard-drive.
The only advantage with some high end ripping products is that some of them make the whole process very automated and simple. But so long as you have the capability to move the mouse around, folllow simple instructions and move files around, then after an initial setup, the above applications will be more than enough.
In fact, if you have possibly a stubborn, hard to rip CD (of which I have a few), then EAC especially will help, as it has a mode whereby it will keep retrying over and over until it either gives up (badly damaged disk) or gets it right.
For all but the extremely well-heeled or extremely lazy, the PC method is enough.
__________________
“Out beyond ideas of wrong and  right, there is a field.
I'll meet you there."
The_Lhc
The_Lhc's picture
It's bull****, ignore them.
__________________
No signature worth mentioning...
MajorFubar
MajorFubar's picture
The best way to check that two WAV files are identical is to invert the phase of one of them with an audio-editor and check that they cancel each other out perfectly. The test is irrefutable.  I’m prepared to bet that a CD ripped by an average a £15 CD ROM and the same CD ripped by one of those devices would pass the cancellation-test, meaning that they are indisputably identical.
__________________
Main gear: Mac Mini > HRT Streamer II+ > Marantz PM66 KI > Mission 794
Also cluttering-up the place:
Thorens TD160 no cartridge; Marantz CD63 mkII KI; Technics SL-P777; Cyrus 2 + PSX; Cyrus Tuner; Nakamichi DR-1
RodhasGibson
RodhasGibson's picture
It's bull****, ignore them. +For all but the extremely well-heeled or extremely lazy, the PC method is enough. +1
nopiano
nopiano's picture
I haven't attempted a comparison so cannot say.  As you noted at the Show, I too saw many using Naim servers and quite a few with NAS devices, either visible or tucked away.
A big 'however', given your commitment to Naim in your signature (to the tune of £30k at a guess), I would have thought an HDX would be an obvious choice, albeit with not much change from five grand.  I spoke to a Danish Naim dealer at the Show who sold just 4 cdps last year but hundreds of streamers.  Based on our chat over lunch, I think he'd say an HDX, especially with a DAC or power supply upgrade, would well surpass even your state-of-the-art CDP (at about half the new cost, so you could probably px yours and come out ahead).
Why mess about with a PC if you can afford not to?
__________________
Hi-Fi: Krell KAV-300cd, Michell TecnoDec/RB250/Grado Prestige Black1, KAV-300i amp, Transparent balanced interconnects and bi-wire to Sonus faber Concerto grand piano speakers, Nakamichi ZX-7 cassette deck, Logitech Squeezebox Touch, Hitachi FT-5500 and Sony S570ES tuners, BCD Engineering stand, RA Powerlink, Chord powerchord, Grado SR60i cans.
AV: Sony Bravia KDL-32EX503 telly, BDP-S370 player with QED HDMI. Currently unused: Denon AVR-1705, DVD-1710, KEF KHT1005.2
Trefor Patten
Trefor Patten's picture
On a mac, you need do nothing more than tick the error correction box in iTunes. I have 3,000 bit-perfect copies of CDS on a WDC hard drive, Playing those files back (i.e. turning the digits into music) is where the magic happens, not in the initial rip.
amcluesent
amcluesent's picture
If basic CD-ROMS didn't read accurately, you would never be able to install software or restore from a backup. It's all marketing cobblers. Bits are bits until you send data into a DAC, then you can argue about jitter etc.
That said, I'm looking at marketing some "directional" SATA cables, which have been burnt-in by transmitting the 'lucky' numbers from Euromillions lottery. A very reasonble £1000 per 30cm.
__________________
Stello CDT200, Squeezebox Transporter, Myryad MT100, Audio Analogue Maestro Settanta REV2.0, Sonus Faber Guarneri Homage  · Squeezebox Touch, Quad FM4\34\306, Sonus Faber Concertinos · Squeezebox Controller
Timpd
Timpd's picture
I was at one of the demonstrations where a  PC ripped track  was compared to a high end rip. They did sound different but I ,and I think one other ,out of 20 preferred the PC rip . So what does that say ?
Tim
edit. It was a blind test.
__________________
fr0g
fr0g's picture
Tim
It says the test was flawed, or rigged.
__________________
abacus
abacus's picture
As has been said, if you use error correction (Which is available on PCs as well as MACs) or programs such as EAC, then there will be no difference. (Essentially what makes the Naim so good is that it re-reads the disc until everything matches 100%, just like EAC)
However the Naim also has some more advantages over a computer, it’s in the same rack as your audio system and you can just pop the disc in and everything is done for you. (Convenience is something you cannot put a price on)
If you don’t mind putting a bit of work in though, you can save yourself a fortune by using a computer.
Bill
MajorFubar
These rippers must do everything but make the tea if they're easier than using a computer.  The hardest part of ripping CDs on a computer is correcting the tags before the rip and making sure albums with multiple CDs are grouped together.  Oh and finding/scanning the 'right' album art (depends how anal you are about that I guess). Surely you must have to do the same thing? There's nothing slowed me down where I've thought 'if only I had a dedicated ripper it would have been faster/easier'. What am I missing?
__________________
BenLaw
BenLaw's picture
Which companies made this claim?
Which company conducted the 'blind test'?
__________________
HiFi   /   A/V   /   Bedroom
Timpd
Timpd's picture
The blind test I attended was by Naim. What bothers me is why I thought the PC / Mac rip was superior to the Naim when 18 out of 20 disagreed with me. My aural faculties are  a bit out of sync with most peoples' it seems.  I thought the Naim system sounded very good otherwise and I had no idea they made speakers too. At least I learned something from the show which I thought was really interesting.
Tim
__________________
The_Lhc
The_Lhc's picture
I wouldn't count on having "learned" anything. One of the guys I was with went to a power cable "demo". First they demoed an amp with a normal power cord, then they turned it off, swapped it for one of their power cables, switched it back on and played the same track again. Except the second time the rep turned the volume up 5dBs higher than it had been for the previous cable...
__________________
fr0g
fr0g's picture
Hence the "rigged" in my previous reply.
It's the only way you'r e gonna pass a power cable test.
__________________
