9 posts / 0 new
Last post
sgowing's picture
Sony BDP-A6000. no 3D through amp.
Hi  I have just bought a Spny BDP-A6000 to replace my Sony PS3.  connected new player through the existing HDMI cable from the PS3. It updated to the latest firmware on start up and all apeared well until I tried to play a 3D movie, getting a message that it needed to be connected to a 3D tv to display 3D content. I re connected PS3 to same cable 3D worked fine, Connected a6000 direct to Tv and 3D worked fine, reconnected  to Av amp and no 3D..
Sony support say that as it outputs 3D direct to tv there is no problem with the player and could offer no further support,. I cannot find any settings in either the player or amp that might be causing the problem,
Richer sounds say they think the player may be faulty and are happy to exchange or swap for an alternative but this involves an 80 mile round trip!  :doh:
can anyone help?
f1only's picture
Last seen: 1 week 5 days ago
RE: Sony BDP-A6000. no 3D through amp.
Having looked at the back of the Blu-ray player on Richer Sounds website, I believe the player has 2 HDMI outputs one for audio & another for video.
That being the case send the audio from HDMI 2 to the amp & the video directly to the tv from HDMI 1 this would or should prove if it is working correctly or not. You may need to go in to the menu on the player to confirm actions & make alterations for the signal paths. The downside is you will need another HDMI lead, BUT cheaper than an 80 mile round trip i think.
Regards ...
A/V Pioneer SCLX59 Speakers B&W 683 S2 685 S2 HTM61 S2 Centre 686 S2 For Atmos x4 ASW610 Sub x2 TV Calibrated 4K Panasonic TX-50AX802B BDP Sony PS3 & PS4 Pro HDMI Monster ISF2000HD Virgin Tivo Netgear ReadyNas104 12TB
sgowing's picture
Thanks for the reply ,  agreed I could seperate audio from video which I know works but  one of the main reasons I upgraded to adedicated  AV amp was to reduce the number of cables run up the wall to the Tv.
michael hoy's picture
Last seen: 1 year 1 week ago
There is no reason to split the video and audio if all the components are 3D capable.
Is the cable from the amp to tv able to carry a 3D signal, can you try this cable direct from A6000 to tv.
AV- Panasonic VT30¦Pioneer LX85¦MA Apex Speakers¦Antimode 8033S¦OPPO 95 BDP
Hi-Fi- Spendor A3¦Cyrus 8 XPD QX¦Quad 909 power amp
Music stored on Server running Windows Home Server.
bigboss's picture
Last seen: 1 day 12 hours ago
I think PS3 is able to pass 3D via a lower spec HDMI cable, but not a standalone blu ray player. Try a high speed HDMI cable.
Edit: Sorry, just noticed the cable works when connected directly. I think you should try high speed HDMI cable from PS3 to amp & from amp to TV.
sgowing's picture
Thanks for the replies, I have replaced both cables and tried bothe existing connected direct to Tv  , no change,looks like a trip back to Richer sounds this afternoon. :?
bigboss's picture
It's more likely your Yamaha amp that seems to be the problem I think.
bigboss's picture
Have you connected your blu ray player to HDMI 1 of the Yamaha? Have you tried other HDMI inputs in Yamaha?
sgowing's picture
Thanks yes tried all HDMI inputs , odd that PS3 works fine
Log in to post comments
