4 posts / 0 new
Last post
Naxos's picture
Last seen: 1 year 6 months ago
Connecting Blu-ray to Supernait
I watch all movie and TV content through my Yamaha YSP-2200, so my Panasonic Blu-ray is connected via HDMI into the back of the soundbar, which is generally excellent. However, for the occasional music programme I'd prefer to listen via my hi-fi amp and speakers. Can I confirm that the best way to do this would be to connect the Blu-ray to one of the digital inputs of the Supernait (or should I use phono connections?), and then mute the soundbar if using that method of listening.
I just can't quite get my head round this one, so any help would be gratefully received.
Main system: Naim CD5 XS, Naim Supernait, Neat Elite SX speakers, Sony KDL40HX853, Panasonic DMP-BDT500, Humax Foxsat HDR, Yamaha YSP-2200 Soundbar, Ipad2, Bose Soundlink Mini
Dining Room system: Denon DM39, Q Acoustics 2010
spiny norman's picture
Last seen: 9 hours 45 min ago
RE: Connecting Blu-ray to Supernait
Assuming by 'the occasional music programme' you mean content on Blu-ray, then yes, you can connect the BD player to the Supernait provided you always remember to set the music track selection to PCM on the disc menu, or (if your player allows) set the S/PDIF digital output of the BD player to default to two-channel PCM.
Otherwise, you could get nasty noises from the hi-fi system if the amp's digital section gets hit with a DD or DTS HD soundtrack, which it won't be able to decode.
Alternatively, you could just use the stereo analogue outs on the BD player
If you want to watch 'the occasional music programme' from the TV. then you'll need a digital (or analogue) connection from the TV to the Supernait, too.
And so, on Feb 22nd 1966,...
Naxos's picture
Thanks! Yes, I realised about the PCM 2-channel output. I might just go for a straightforward phono connection to keep things simple. I assume I just then mute the soundbar or do I need to select the output on the Blu-ray player in each case, depending on which system I want to listen to?
Nah – just leave both outputs always on, and just mute whichever system you're not listening to at the time.
Log in to post comments
