Pro-Ject launches super-speedy vinyl cleaning system
The VC-S comes with a newly developed 'Wash it" cleaning fluid which claims to not only offer good cleaning results, but dries quickly to leave no residue.
To clean records using the machine, the record needs to be spun on the support clamp, which keeps it away from the main platter of the machine. When spinning cleaning fluid can be applied and evened out on the surface with the supplied brush.
The attached vacuum arm then sucks up the cleaning fluid and impurities, leaving you with a clean record.
The used cleaning fluid can be emptied from the tank by inserting the supplied spout, and Pro-Ject says you’ll need to clean roughly 1000 records before the tank is full.
For cleaning 78 rpm shellacs, an optional ‘Wash it 78’ cleaning fluid is available. The VC-S vinyl cleaner is available now for £299, with accessories and cleaning fluids ranging from £15 to £40.
Best turntables 2016
Max is a staff writer for What Hi-Fi?'s sister site, TechRadar, in Australia. But being the wonderful English guy he is, he helps out with content across a number of Future sites, including What Hi-Fi?. It wouldn't be his first exposure to the world of all things hi-fi and home cinema, as his first role in technology journalism was with What Hi-Fi? in the UK. Clearly he pined to return after making the move to Australia and the team have welcomed him back with arms wide open.
