5 posts / 0 new
Last post
josh05's picture
Last seen: 1 year 7 months ago
Upgrading Opamps?
Was just wondering whether doing this is a worthwhile upgrade? If anyone has done it would like to hear your thoughts on it. thanks Smile
Olli1324's picture
Last seen: 4 years 2 months ago
Re: Upgrading Opamps?
The op-amps in what? A number of people here have had success with upgrading op amps in DACs and the like.
One thing to watch out for is whether your choice of upgrade is compatible with the thing you are upgrading. A quick search on google of the item name+'op amp upgrade' or something should yield a few discussions on exactly what you are after.
Personally I am a believer in op amp upgrades; definitely something worth investigating if you have the time/money/will.
PJPro's picture
Last seen: 2 years 3 months ago
This page might be of interest.
josh05's picture
sounds good, might look into upgrading my Marantz with new ones if i can and if its not too pricey.
Anonymous's picture
check out audioupgrades website im looking into upgrading the internals of my dac - they are based in doncaster.
Log in or register to post comments
