8 posts / 0 new
Last post
muljao's picture
Last seen: 1 day 5 hours ago
Powered speakers sub 400 pounds
Hi all,
My brother wants to put a turntable in his apartment. His partner is not to keen on the idea so if it's to go ahead it will be a turntable and speakers without an amp. I have showed him some examples (he likes good sound but it doesn't have to be the ultimate) and he will likely get a 250 pounds turntable with built in preamp.
He is happy to pay a little more for powered speakers (not necessarily active, just no amp). Is there anything that ye could recommend for say 400 pounds. Other connections such as Bluetooth or Spotify would be nice but not crucial. They would though need to be domestic friendly in appearance.
Everything is a lie, except the truth
insider9's picture
Online
Last seen: 4 hours 30 min ago
Yamaha NX-N500
Welcome back. I'm only aware of them and not heard them. They have been well received with Trusted Reviews giving them 9/10. Since the review Tidal, Deezer were added.
They're available at £454 so just over budget but have a fully working streamer and I believe they look good too.
Nelis87's picture
Last seen: 4 hours 10 min ago
Q acoustics bt3
Q acoustics bt3
muljao's picture
Thank you both.
Thank you both.
@insider9- I had to leave for a while. I couldn't afforf to read the forums Smile
insider9's picture
Online
muljao wrote:
Thank you both.
Haha, I know what you mean. Good to see you back Smile
davedotco's picture
Last seen: 1 week 2 days ago
NX N500
Are probably the most complete solution though a little over budget. Functionality is unsurpased, network streaming, Spotify, Tidal etc, analog inputs, Bluetooth, Airplay, the lot really, comes with a regular remote but the MusicCast app is first rate.
Sound quality is pretty good, proper active setup with a lot in common with Yamaha's hugely successfull HS series monitors, only downside is the lack of grills which give them a 'studio' style look.
If you want something more hi-fi looking, you should look at the Dali Zenzor 1ax at around the same price, nothing like the flexibility of the Yamaha but a pretty package at about the same price.
bigboss's picture
Last seen: 6 hours 34 min ago
Audioengine A5+.
Audioengine A5+.
gasolin's picture
Last seen: 10 hours 24 min ago
Is the budget 400  or 150
Is the budget 400  or 150 pounds?
Size of room and muisc taste?
Nad 3020I,Marantz CD5005, RP1 Queen LE, Focusrite Lightning iTrack solo,White pair of Genelec 6010a, inakustik, supreme cable
Log in or register to post comments
