17 posts / 0 new
Last post
Bumrah's picture
Last seen: 14 hours 12 min ago
Cyrus 8VS2 Replacement
Hi Guys
Had a Cyrus 8Vs2 for a while now and it's been a great servant over the years. Had it partnered with various kit and always been happy with it. Anyway i am looking to replace it but only looking to spend around £600 ideally. I have been briefly looking at the
1. Rega Brio,
2. Rega Elex-R
3. Audiolab M-One.
Always liked Rega and had some great speakers previously (R3's) and the reviews of the Brio all seem excellent. It looks great and will fit in well with the space i have, however it has no digital inputs which isn't the end of the world but i listen to a lot of Sonos via a Connect, although the built in DAC sounds pretty good to me.
The Elex-R seems like a good option too and is in a smiliar price bracket to my Cyrus (when it was new).
However the Audiolab has decent reviews and has a DAC an digital input options.
Overall sound quality is the most important thing to me, of the Audiolab is on a par then i will be tempted as it has more flexibiltiy.
The rest of my system is
PSB Imagine Mini speakers
Sonos Connect (used to stream lossless)
Cyrus CD8X (hardly used now)
Really interested to hear people's opinions, will the Brio be on a par or better than my Cyrus or will it offer a totally different sound? what will the other options offer?
gasolin's picture
Online
Last seen: 6 hours 41 min ago
I think the Audiolab M ONE is
I think the Audiolab M ONE is no match for rega Slightly lean balance Treble lacks refinement according to whathifi, you should also consider the Cambridge audio CX60/80 and Marantz PM8005
PSB should work fine with nad amps, might consider listening to the Nad D3020 or the new Nad D3020 V2
Cambridge Audio CXA60, Nad C516BEE, RP1 Queen LE, Focusrite iTrack Solo,Black Dynaudio Emit m10 on isoacoustics stands,DH LABS Odyssey, inakustisk premium usb and rca to rca.
insider9's picture
Online
Last seen: 3 hours 20 min ago
Hi, I've not heard any of the
Hi, I've not heard any of the amps only of them. I suspect neither of the mentioned amps would be an upgrade to your Cyrus bar Elex-R. But it's only my best guess. Can you demo?
Bumrah's picture
Thanks for your responses. I
Thanks for your responses. I’m happy to look at NAD options too. I will definitely demo but just trying to gather a shortlist at the moment.
insider9's picture
Online
Have you considered adding
Have you considered adding PSX-R to your Cyrus?
emcc_3's picture
Last seen: 3 hours 50 min ago
The Arcams A29 (£499) and A39
The Arcams A29 (£499) and A39 (£899) can be had at a good price at the minute as the model is in run off.
Rega Planar 3, Roksan K3, Sonos Connect, KEF R700's.
davidf's picture
Last seen: 7 hours 38 min ago
Have you considered a Cyrus One?
www.thelittleaudio.company jewellery quarter, birmingham
amphion | audio technica | bluesound | convert technologies | clearaudio | eclipse | electrocompaniet | hegel | heco | innuos | kef | larsen | moon | ophidian | svs | technics
Bumrah's picture
I did have a brief look. I
I did have a brief look. I know it is about how they sound but they are so ugly! I will try and have a look at one in the flesh though.
Do they have the traditional Cyrus sound?
Bumrah's picture
Thanks, will have a look. I
Thanks, will have a look. I haven't heard any of the new Arcam stuff, i have had 2 Arcam amps in the past and found them a bit too laid back, not particularly exciting. Hopefully they have changed a bit.
Bumrah's picture
Yeah i looked at them a while
Yeah i looked at them a while ago, not really sure i want to go down that path. If i get rid of the CD8X then i might have the space for one.
seemorebtts's picture
Last seen: 4 days 11 hours ago
You can get a primare i22
You can get a primare i22 with a dac for £799 at the moment brand new which cost £1500. I also like the rega
Primare i32, primare cd32, usher mini dancers Speaker's sony bravia kd65xe930
Mark Norman shared 4 photos with you from the Flickr app! Take a look:
https://www.flickr.com/photos/94843557@N05/shares/4jd70x
https://rover.ebay.com/rover
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F232675828597
davidf's picture
It is based in the amplification used in the Lyric and Stereo 200 power amplifier, so a little different to the ‘classic’ stuff. And it does look better in the flesh.
davidf wrote:
could be a fantastic upgrade
davidf's picture
Definitely a more beefy presentation.
plastic penguin's picture
Last seen: 3 days 12 hours ago
The new Cyrus does seem a logical step. Think it is always wise to stick with a brand you know and like, especially if demoing is a problem.
Leema Tucana MKII; Arcam CD73; PMC TB2i; Pro-ject Classic/Goldring 2500; Denon TU260 MKII
Pages
Log in to post comments
