Sennheiser Momentum Free review
Sennheiser’s Momentum range of headphones serves up yet another hit...
What Hi-Fi? Verdict
Another impressive, wireless addition to Sennheiser’s talented range of Momentum headphones
Pros
    Impressive clarity
    Powerful, musical performance
    Excellent dynamics
Cons
    Call quality could be better
    Tiny hint of harshness towards the top end
Why you can trust What Hi-Fi? Our expert team reviews products in dedicated test rooms, to help you make the best choice for your budget. Find out more about how we test.
Sennheiser's Momentum range already boasts a pair of five-star, Bluetooth in-ears – the Momentum In-ear Wireless – so does it really need another pair of wireless headphones? The answer is yes, because these are among the best wireless headphones you can currently buy.
The Momentum Frees (also known as Sennheiser M2 IE Free, and furthermore also known as Sennheiser M2 IE BT - so be sure you and your retailer understand each other) offer similar features and functionality to their siblings. The only key differences are styling and battery life.
Comfort
The Frees have an unfussy, simple design, with a single short length of cable running between the earpieces. You can adjust the length via the attached slider, and can choose to run the cable either behind your neck or under your chin.
The In-Ear Wireless, on the other hand, use a chunkier neckband design which sits on the back of your neck. They feel more intrusive, whereas the Frees are more flexible and easier to roll up to stow away in a pocket or bag.
MORE: How to avoid buying fake headphones
Features
The main thing you sacrifice with the Frees is a few hours of battery life – the drop from ten hours to six could be something to bear in mind.
But if this isn’t a major issue, and you’re a fan of the simple styling, then you’re going to be well served by these Sennheiser headphones.
The box below the right earpiece hosts an in-line mic and controls for music playback and volume. A long press on the top or bottom buttons skips track and a short one changes volume.
Tapping the middle button plays and pauses when you want to answer a call.
MORE: Best headphone deals: in-ear, over-ear, wireless and more
When they’re not pumping music into your ears, you can connect the earpieces to each other via integrated magnets.
It’s a neat idea in theory, but the execution here is a bit fiddly. It doesn’t take a lot of movement to break the connection, so you might want to use the supplied carry-case instead.
The mic also sits too far away from your mouth, occasionally making it difficult for the person on the other end of phonecalls to hear what we are saying.
Pairing for the first time is quick and easy. A voice lets you know when to look for the headphones on your device’s Bluetooth settings and, when you power them up on future occasions, it confirms you’re connected almost instantly.
MORE: Best in-ear headphones
Sound
The Bluetooth receiver and battery have been kept away from the earpieces, allowing Sennheiser to design them in an identical way to the buds used in the wired version.
This shines through in their sonic character – they have the same powerful and dynamic sound we’ve come to expect from the Momentum in-ears.
Play Lenny Kravitz’s Again and there’s a real sense of weight and purpose to each impact from the kick drum, as there is to every chord fired out by the lead electric guitar. You can’t help but tap along in approval.
The in-ears deliver an impressive sense of clarity and detail for the money. You can hear every instrument and note clearly defined - these headphones make rivals such as the Bose Soundsport Wireless sound almost thick and muddied in comparison.
Even with more compressed tracks, the headphones refuse to get bogged down and still manage to carve out bass, mids and highs with expert precision.
We play Main Title and Escape from The Last Jedi soundtrack, and the Sennheisers communicate all the dynamic shifts with ease.
MORE: How to choose the right pair of headphones
The foundations are laid by the weighty drums, the flow of the track dictated by delicate strings before the wind instruments launch the track into the stratosphere.
There is a tiny sliver of sharpness at the top end that can be exacerbated by poorer recordings at high volume levels. But it tends to be subdued by general background noise when you’re out and about, and doesn’t spoil enjoyment of the sound.
We also use the headphones with a range of video sources, from You Tube clips to BBC iPlayer and Sky Q, without noticing any signs of audio delay when marrying up the sound to video on a smartphone.
Verdict
At the risk of sounding like a broken record, the Momentum Frees are yet another fine addition to Sennheiser’s Momentum family.
If you want wireless convenience combined with excellent sound quality, this is another pair you’ll seriously want to consider.
MORE:
Best wireless earbuds
See all our Sennheiser reviews
What Hi-Fi?
What Hi-Fi?, founded in 1976, is the world's leading independent guide to buying and owning hi-fi and home entertainment products. Our comprehensive tests help you buy the very best for your money, with our advice sections giving you step-by-step information on how to get even more from your music and movies. Everything is tested by our dedicated team of in-house reviewers in our custom-built test rooms in London, Reading and Bath. Our coveted five-star rating and Awards are recognised all over the world as the ultimate seal of approval, so you can buy with absolute confidence.
Read more about how we test
