EXCLUSIVE REVIEW: Panasonic's new DMR-EX78 DVD and 250GB hard-disk recorder tested
It's been a while since we last tested a DVD/hard-disk recorder, but with a string of new models on the way from the likes of Panasonic and Sony, we decided it was time to get up to speed with the latest contenders.
One of the first to arrive in our listening rooms was the £300 DMR-EX78 from Panasonic, so we've been itching to give it a whirl and find out how it performs.
Want to know how good it is? Well find out all in this special Bank Holiday review, brought to you exclusively by whathifi.com.
Panasonic DMR-EX78
DVD recorder £300
5 stars
For
Brilliant blend of performance, flexibility and usability; terrific value
Against
Nothing at all
Verdict
You can get slightly cheaper DVD recorders, and you can get some with even larger hard disks, but this Panasonic offers a near-perfect blend of flexibility and value
What with all the fuss surrounding hard-disk PVRs and Blu-ray disc players, a new DVD recorder might not seem the most exciting newcomer of 2008 - but in many ways, Panasonic's DMR-EX78 is actually one of the best buys we've come across so far this year.
That's partially because it's so finely tuned, so obviously a product honed by years of DVD recorder development. Panasonic has worked incredibly hard not only on its features and performance, but also on its usability, so despite its astonishing breadth of capability, the 'EX78 is actually relatively easy to use.
The Panasonic is a combination of hard-disk and DVD recorder, with 250GB built-in storage space and the ability to burn content on to every blank DVD format except DVD+R.
That massive hard-disk can store up to 441 hours of TV using the longest-duration EP recording mode, dropping to 55 hours in the highest-performance XP setting (which is what we'd use – 55 hours is surely enough for anyone!).
Freeview Playback support
As you'd expect, the Panasonic includes a Freeview digital TV tuner, but it omits an analogue alternative. By way of compensation, it also gives you Freeview Playback support, allowing for simple series recording functionality, plus other niceties.
Intriguingly, the DMR-EX78 can also be used as a music server. It allows you to rip CDs to its hard-disk, and comes pre-loaded with the Gracenote compact disc database to allow for automatic display of artist, title and album information. Panasonic's website should soon offer free updates to the database, too.
Additionally, a front-mounted USB port allows for easy connection to an MP3 player or digital storage vault for digital transfer of MP3 music and JPEG photo files, and there's even a Firewire input for digital camcorder users.
1080p video upscaling
Once installed – the work of moments – the DMR-EX78's image quality quickly astounds. It's equipped with an HDMI video output, as you'd hope, coupled to 1080p video upscaling if needed, and that, plus its excellent TV tuner, means broadcast pictures are simply terrific.
Digital block noise is kept well in check, images have snap and vitality, and jagged edges are only notable by their absence.
It's scarcely a surprise, then, that recordings to either hard-disk or blank DVD are equally impressive when using XP mode, while dropping to SP (the next option down, good for 110 hours) reveals only a little more screen noise.
Throw exceptional DVD-Video replay and punchy sound – even with ripped CDs – into the mix, and you've quite clearly got an accomplished performer. That, coupled to the Panasonic's sheer value, makes it an unbeatable bargain.
What makes it special?
Large hard-disk
The Panasonic gives you 250GB of inbuilt storage space, enough to offer 55 hours of recording in best-quality XP mode, 110 hours in SP mode, 221 hours in LP mode and 441 hours in EP mode.
Music matters
This isn't just a video recorder: it's also a music server. Use it to store your CDs in 384kbps form, and it'll automatically load up the correct artist, title and album information from its inbuilt CD database.
Socket to me
This recorder has loads of connection options: it can accept MP3 and JPEG files from USB, digital video via Firewire, and it also includes conventional Scart, S-Video and composite video ins.
Easy to use
The Panasonic's on-screen menus and user interface are exceptional, and its support for Freeview Playback means it's simplicity itself to set this deck up to record your favourite TV series
As with most modern DVD recorders, the Panasonic makes use of the HDMI CEC system (consumer electronic control) to simplify its operation. If you use it with a Panasonic TV, you can operate both components - even making recordings - with one handset
The Guide Plus electronic programme guide is beautifully rendered, so setting recordings is ultra-easy. Checking through the content you've recorded is fun too, the Panasonic presenting each individual recording as a moving 'thumbnail' graphic
Want to build a complete system? Now Add These:
Panasonic TH-42PZ80
Plasma TV £875
Take full advantage of the DMR-EX78's convenience features, and also enjoy its 1080p video upscaling with this exceptional Full HD plasma TV.
Onkyo TX-SR606
AV receiver £400
The latest Onkyo is a minor classic, able to decode all forms of surround audio (including high-definition modes) and deliver every audio option with thunderous drive and authority.
B&W 685 Theatre
Speaker package £1206
Scintillating sonics with both music and movies: this is a conventionally styled speaker package, to be sure, but it's ideal to take full advantage of the Panasonic's music server abilities
Tech specs
Analogue tuner 0
Freeview digital tuner 1
Plays
DVD-A N
SACD No
MP3 Yes
DivX Yes
DVD-R/-RW Yes
DVD+R/+RW Yes
DVD-RAM Yes
Records
DVD-R/-RW Yes
DVD+R/+RW No
DVD-RAM Yes
Hard Disk (Gb) 250
Inputs/outputs
HDMI out 1
DVI out 0
Component out 1
RGB Scart out 1
S-Video out 1
Composite out 1
Optical digital out 1
Coaxial digital out 0
FireWire out 0
Phono audio out 2
Six-channel analogue out 0
RGB Scart in 1
S-Video in 1
Composite in 1
Phono audio in 2
FireWire in 1
Video scaling 1080p
Dimensions (hwd, cm) 6 x 43 x 33
Technorati Tags: 1080i, 1080p, DVD-RAM, DVD+R/+RW, DVD-R/-RW, DiVX, DVD-Video, DVD recorder, Freeview Playback, Freeview, Gracenote, FireWire, HDD recorders, 250GB, HDMI, JPEG, MP3, optical digital out, Panasonic DMR-EX78, RGB Scart
Andy Clough
Andy is Global Brand Director of What Hi-Fi? and has been a technology journalist for 30 years. During that time he has covered everything from VHS and Betamax, MiniDisc and DCC to CDi, Laserdisc and 3D TV, and any number of other formats that have come and gone. He loves nothing better than a good old format war. Andy edited several hi-fi and home cinema magazines before relaunching whathifi.com in 2008 and helping turn it into the global success it is today. When not listening to music or watching TV, he spends far too much of his time reading about cars he can't afford to buy.
