System Evolving
I woudn't bother with new speakers. The BR2 is a great speaker and you might regret selling them.
ohhhh so cute the big system had a baby
At least the tacima CS929 will keep warm this winter....
Nice looking system, there is something so pleasing about a simple set-up and I love the stand arrangement. if its logistically possible try plugging the amps (particularly the power amp) directly in to a wall socket and see if it sounds better.
Thanks for the kind comments everyone... system sounds nice 75% of the time. I do like the BR2s don't get me wrong but they are now the weakest link.. I feel they don't quite have the refinement to tame the (foward and detailed) cyrus sound.. the system can edge into brightness with some recordings. At any rate the BR2's are "borrowed" from my BR AV system downstairs (BR2's, BR1's, BR CENTRE, BR SUB) so I won't be selling them.
Also on the lookout for a second-hand pre-vs2, having heard that a dedicated preamp sounds a fair bit better than using the 6vs2 as pre. Also I'll be able to sell the integrated at that point to recoup most of the cost.
Will definitely try plugging the 6 power straight into the wall (although it's over 4 metres, so the cable will have to be a cheapy)... have heard about conditioners "strangling" the power sections before... although the system is definitely not short on dynamics or punch.
Looks great. And I bet sounds great too. Although I think the Dynaudios Will make make it even better. A lot of Cyrus owner choose Dynaudio for their setups
