RickyDeg's sleek system with Monitor Audio Apex
71 replies [Last post]
RickyDeg
RickyDeg's picture
Moved to a new apartment last year and wanted something simple and clean that wouldn't dominate the room yet still deliver excellent performance. As you will notice from the pictures black & white is the flavor of my interior and the speakersystem Monitor Audio Apex fitted that bill perfectly. I currently own a 7.2-system, but the extra satellites have yet to be mounted. Once that is done they will serve as height-channels, but until I've found a suitable a/v machine with an appropriate surround mode I'll stick with a 5.2-system.
RickyDeg's system
The design of the beautiful Apex felt like the icing on the cake in this decor. The room itself is rather small and cosy, but I dont see that as anything negative, infact whenever I fire up this system it doesn't feel as though the room itself is a limit. The soundstage is big and bold. The thick rug on the floor proved excellent for room acoustics.
RickyDeg's system
The front trio of speakers are naturally placed lower than ideal (ear-level) but it was a necessary compromise. On the opposite side of the room are windows which naturally present a certain amount of glare on my display (and the glossy speakers). Normally I dont mind this too much, but it can be annoying on a bright day. Thankfully blinders have helped.
RickyDeg's system
Previously I've always had a desire to see my electronics, but in this livingspace I felt it was more appropriate to hide them way, and this brilliant a/v-cabinet was perfect. It's spacious and well-built. The subwoofer AW-12 may look a little crammed in the corner, but this spot actually works well. Naturally, in a small room one has to make effective use of available surfaces.
RickyDeg's system
The rear pair of Apex A10 satellites are placed fairly ideal, I think, even though a bit more distance could have been good. I don't feel as thought they are over-powering though, thankfully. My second AW-12 subwoofer is "hidden" away in the corner behind the sofa, adding to that extra feeling of bass 'slam' and 'depth' but most importantly help improve bass dispersion.
RickyDeg's system
Truthfully I was doubtful at first about the design of these speakers, as I my initial reaction was "odd" - but that quickly went away and I realised how beautiful and unique the Apex truly are. I dislike the supplied table-top feet however, and removed them in favor of descreet flat resonator-feet by Valhalla Technology. Continuing to experiment on this issue though.
RickyDeg's system
Even though the bigger A40 centerspeaker sounds slightly different than the smaller A10's the integration between them is still very good, and I never really find anything annoying. Completely identical speakers in each and every location is ideal however, as far as I'm concerned, but in this situation that solution was not really an option for me.
RickyDeg's system
Behind the left cabinet-door is my much beloved CD/HDD-player Yamaha CDR HD-1500 with a retro-fitted 400GB harddrive for all my music. Uncompressed high-quality PCM only. Don't care for Airplay, iTunes and whatnot. HD-satellite receiver and Logitech's RF-system receiver are both very smallish. The excellent Oppo BDP-93 serve as a blu-ray transport only.
RickyDeg's system
My trusty Denon AVR-3808A is a great receiver. I was first introduced to Audyssey through this machine, and it's pretty much transformed my system. Dynamic EQ is brilliant aswell, and make it stand apart from others I believe. Although not the latest MultEQ-version it's evident what kind of benifits this calibration-system can bring. Movies are great - music is decent.
RickyDeg's system
First thing I always do when installing a machine is to replace the lame and cheap feet they come mounted with. I am a strong believer in isolating your equipment, whatever their pricepoint. Improvements can be dramatic at times, but mostly only subtle, but benifits are there regardless. These are Nordost Pulsar Points - excellent stuff!
RickyDeg's system
My probably best investment is somewhat unlikely (?) a remote control; Logitech Harmony 900. It comes with an excellent RF-system for hiding the electronics away. It has worked wonders in my system and installation. I can sit in the kitchen with the remote and control the music I'm hearing from the livingroom. Brilliant. It's also very comfy and easy to set up.
Ok, that's it for now Cool I aim to replace my trusty receiver soon though. But having tried so many potential replecements lately (Pioneer SC-LX83/85, Anthem MRX700 and Primare SPA22) yet seeing them all fail against the Denon I'm guessing my quest will be long and time-consuming. Perhaps I'll find a separates-solution, or stick with integrated. We'll see. Cheers all.
__________________
>>> VIEW MY SYSTEM THREAD HERE <<< Current equipment: DENON AVR-3808 | OPPO BDP-93 | MONITOR AUDIO APEX 5.2 | SAMSUNG LE-52B755 | YAMAHA CDR-HD1500 | HUMAX BXR-1000 HDTV SATELLITE | ISOTEK EVO3 SIRIUS | NORDOST PULSAR POINTS | LOGITECH HARMONY REMOTE 900
matthaskell
matthaskell's picture
RE: RickyDeg's sleek system with Monitor Audio Apex
What a great looking system and a brilliantly presented thread.
Thanks for sharing
Matt
__________________
Leema Pulse | Denon 1911 | LG 50" plasma| Marantz CD6003 | Sony 370 bdp | B & W 602 S3 | AE Radience sub | AKG K450 | AKG K44 | Senns 300cx II | iPad2  | Apple TV | Spotify premium.
El Hefe
El Hefe's picture
Everything looks so neat. From the set up to the room and to the thread. Well done.
__________________
HiFi: ClearAudio Concept TT, Musical Fidelity M6i and M6 DAC, M1s (CDT, CLiC, ViNL), Onkyo TA2600, SONY MDSJA20ES MDP, ProAc D18 with full Siltech cabling.
HT: Samsung UA55B7000 LED, OPPO BDP 95-EU,Marantz DV4003, Yamaha RX-V2067, Philips DVDR7300H, Infinity Primus Center, Wharfedale WH2, SW15 Sub, Mission M34i with full QED cabling
Bedroom: BRIK Audio BT Stage, Bose WAVE Music Sytem III
HeadFi: Alessandro Grado MS Pro, Bryston BHA-1 headphone Amp.
Office: iTunes, UD100 USB DAC, Bose Companion II, Musical Fidelity HPA headphone amp, Bose Over The Ear
CnoEvil
CnoEvil's picture
RickyDeg wrote:
RickyDeg's system
Great job.....and I particularly like the "rear surround bushes", which connected up should give you 9.1 surely. Wink
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
BenLaw
BenLaw's picture
Online
Looks great Ricky  Smile And looks like the cabinet has plenty of room for separates  Wink
__________________
HiFi   /   A/V   /   Bedroom
ric71
ric71's picture
Very nice Ricky. Have swapped my ARCAM out for an Anthem MRX and it sounds brilliant in my room.
__________________
Anthem MRX 300(used as processor),Anthem Statement A5 power amp,MK S150MKII's LCR,MK S150T rears,Paradigm Studio Sub15,Perfect Bass Kit,Sonos ZP90 ,Qnap NAS,Pioneer BDP-LX55,Isol-8 Cleanline2 mains conditioner,SKY+HD,Audioquest Diamondback interconnects. ATV3,iPad4.
SupertoMMo
SupertoMMo's picture
Nicely put. I envy ur room.
__________________
My System   Memoirs of an Audioholic:My Hall of Fame
Source: Linn Majik DS-I Integrated Amplifier: Accuphase E407 Speakers: Totem Arro Cables and Accessories: Copper Colour Interconnect, Nordost Heimdall Speaker, Shunyata Researh Venom 1, Totem Beak
Auditioning: Linn Majik 140/NHT Classic 3
This and That: iPhone 4, iPad2, B&W P5, Twonky Media on Mac mini early 09
RickyDeg
RickyDeg's picture
THANK YOU to everyone for taking the time to read & comment! Appreciate it! Laughing
__________________
ANLI
ANLI's picture
wow looks absolutely amazing! Tongue out I like the 'clean' look of the decór, bet it sounds great too!
atanakata
atanakata's picture
Beautiful system fits perfectly in a lovely looking room. What else can I say...Well Done.Hope you enjoy it Smile
__________________
Samsung UE46D6530 > QED Performance HDMI > Denon AVR-1909 > Chord Active Silver HDMI > Denon BDP 2010 > Leema Linx 1 Interconnect > Leema Pulse Stereo Amp. > ProAc Signature Black Speaker Cable > Beresford TC-7220 2-way Audio Switch > Atlas Hyper 1.5 Speaker Cable > M.Short Mezzo 6,Mezzo 5 and Mezzo 1 on Atacama Nexus 6i > Wharfedale SW150 Sub
My Set-Up
john1000000boy
john1000000boy's picture
Like this system too.  Could you not move the cabinet into the room a little and then get the fronts on stands or wall mount them.  Seems narrow.  Would love to hear this when all the spkrs are hooked up.  The listener will be right at the heart of it!!
__________________
Panasonic Tx-P65ST50B. Pioneer SC-LX82, Pioneer BDP-LX52, Pioneer PDP-4280XD. Monitor Audio Rx6 Av12. Apple Macbook, Apple Ipad 3g 64gb, Apple iphone 4 8gb, Apple Ipod Touch 32gb, Apple Time Capsule 2tb, Apple TV. Sky HD. Microsoft Xbox 360. Monster Beats Studio HD. Sennheisser CX 300 II. QED Silver Spiral, QED Anniversary XT Speaker Wire, QED HDMI-P. One For All Xsight Touch. Belkin N Router. Devolo Home Plugs. Iomega 1.5tb Hard Drive. Spotify Premium. Philips Fidelio AirPlay spkr dock
My System Thread Best pics start on Page 4:
http://www.whathifi.com/forum/your-system/finally-my-new-system-as-ofnow
RickyDeg
RickyDeg's picture
Hey John, thanks for posting! You are welcome to a movienight! cool
Since it is a smallish room and the cabinet is rather large (good for housing big electronics) I am limited on my options of how to place it. Good point about the 'narrowness' issue because I feard that too at first. But since the front trio of speakers are placed on an equal plane the soundstage is very coherent and uninterrupted as sound pans from side-to-side. The soundstage also feels larger and wider than one might think (judging by the close placement of the speakers) much thanks to their excellent dispersion I belive. Don't enjoy having L/R too far off from the display anyway.
Besides, even if I wanted to I cannot really move them now... I have drilled small holes in the cabinet to hide the speakerscables and keep things "neat", hehe.
__________________
ANLI
ANLI's picture
How will you place the height speakers? Wish we could have those too in our listeningroom crying
RickyDeg
RickyDeg's picture
Hey ANLI, hope you are still enjoying your Apex-system?!
Good question by the way. I plan to mount a wide single shelf in white 2-3 feet above where the top of the LCD-display ends, and then place the two Apex satellites ontop of that. Trouble is I will have to drill up the wall because I need to hide the speakerscables that connect them. I hate seeing dangling cables on walls or cheap solutions on trying to hide them, so best to integrate them inside the wall. More work of course, but hopefully worth it.
__________________
RickyDeg
RickyDeg's picture
Thank you! I see you have the Mezzo-speakers, they are lovely. I have seen and listened to them a few times! Even though I'm now a "compact speaker person" I still keep an eye out for floorstanders, just for the fun of it, hehe.
__________________
ANLI
ANLI's picture
Seems it would be alot of work to integrate the height speakers! Apex-nirvana!
But I'm sure it will look and sound really really nice! (like it already does)
