Noisy Sky HD box
Hi All,
I've had my Sky HD box for about 6 months now, but ever since it was delivered and installed I've been unhappy with the noise the box makes in comparison with my old standard Sky box.
I called Sky to ask if the noise was normal and I was told that it is because the box is contunually updating it's data and if it gets hot the fan kicks in to keep the box cool. I was even advised to turn off Sky Anytime which apparently is constantly updating.
The box is well ventilated on a proper AV stand and even with the Sky Anytime function disabled, my Sky HD box is noisey and can be heard over tv dialogue if it is a quiet scene or the volume is simply turned down low. Furthermore, I don't see why I should pay for an HD service and have to forego some of its functionality (i.e. Sky Anytime) to keep the noise down!
Has anyone had a similar problem? If so, how did you resolve it?
Any suggestions/advice welcome.
Many thanks.
I had a problem where the fan got stuck "on" continuously for a couple of days, which was very noisy. I switched the mains power on and off and it seemed to cure it. No problems since.
MA PL200s, PL350C, PLW-15, PL100s
Onkyo PR-SC5509 -> Leema Acoustics Pyxis, Hydra II (x2) & I
JRiver 18 Leema Acoustics Elements DAC Panasonic BDT-310 PS3 X360 Wii Virgin Tivo
Samsung PS64D8000
