My System...
22 replies [Last post]
Alec
Alec's picture
Now, dont all laugh at once. It sounds ok to me.
EDIT - GRRR! No idea what went wrong there. I've looked around on flickr to check who can see the photos etc...but nothing seems to be wrong there.
__________________
Formerly known as al7478...
HC: Panasonic PXP 42 V20; Panasonic DMP BD35; Humax Foxsat-HDR
Music: Optical out from Asus P7H55-M Motherboard into AVI ADM 9.1 speakers.
"Music will provide the light you cannot resist"
John Duncan
John Duncan's picture
Re: My System...
"Oops! You don't have permission to view this photo."
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
Alec
Alec's picture
Re: My System...
Ah. Did you go to the site then...? If so, i must need to go back and make it so that anyone can see it, then link to it. Anyone know flickr and can tell me what to do?
__________________
tom83cat
tom83cat's picture
Re: My System...
You could re-upload the photo and make sure you check the box for "public" and not "private"
tom83cat
tom83cat's picture
Re: My System...
Alec
Alec's picture
Re: My System...
Cheers, I'll give it a go.
__________________
tom83cat
tom83cat's picture
Re: My System...
See... it does work
tom83cat
tom83cat's picture
Re: My System...
Also... if you go into Flickr and click on one of your photos, on the right hand side it says "Additional information" and two lines down it should say something like "Only you can see this photo (edit)"... click on the edit and you should be able to turn the private off!
Alec
Alec's picture
Re: My System...
TV to the left, PC, Amp to the right. Couch about 10 feet from them, against a kitchen counter - its an open plan kitchen/front room thing. Speakers approx 10 feet apart, toed in slightly.
Like i said, dont all laugh at once.
__________________
Alec
Alec's picture
Re: My System...
OK, i give up. it definitely says anyone can view them.
__________________
Alec
Alec's picture
Re: My System...
click here
HUZZAH!!! With apologies to all, thanks for the help, especially to PJPro!
Theres a description of my listening room under one of the photos. And my gear is in my sig, apart from the TV (model unknown, but is a 32" Panny), and the DVD player - Panny DVD - S52.
Might upload some better lit photos at some point, but i had to borrow the camera. Hopefully these 2 give an adequate idea of where everything is.
__________________
tom83cat
tom83cat's picture
Re: My System...
Alec
Alec's picture
Re: My System...
tom83cat ithankyew...!
__________________
fr0g
fr0g's picture
Re: My System...
Al, in Flickr, click on All Sizes.
Then click on the size you want
Then copy the HTML from box 1 and paste straight into this window.
__________________
“Out beyond ideas of wrong and  right, there is a field.
I'll meet you there."
Alec
Alec's picture
Re: My System...
000_0012
000_0011
Cheers fr0g. I think i reciprocated in the apropriate way by the way, but i shall be using he site as little as possible.
__________________
fr0g
fr0g's picture
Re: My System...
000_0012
000_0011
no worries. I use it as I enjoy a little bit of photography too...bit dim upstairs right now, but im gonna post my system too :=)
__________________
