My system
16 replies [Last post]
f1only
f1only's picture
Thought i would finally post a few dodgy pictures of my setup.
front
sorry for the picture quality done with a mobile phone..
cack
Fr/r
 As you can see im at a little disadvantage with the room shape so have tried to make the best of a bad deal.
FL
RL
A bit difficult to get it sorted on the surrounds too with space as seating is crammed
Surround R
The B&W 610 subwoofer is under a table below my front window on a piece of granite. I will redo these pictures at a later date due to the poor quality.Frown
Regards all
bigboss
bigboss's picture
RE: My system
Wow! I love all the wood!! Nice colour too!!  Tongue
__________________
BenLaw
BenLaw's picture
RE: My system
Looks like a very neat solution for the room, good job  Smile Now just time for a universal remote  Wink
__________________
HiFi   /   A/V   /   Bedroom
Xanderzdad
Xanderzdad's picture
RE: My system
Love it - just shows what can be achieved with a little thought, even if the room (as you say) is an awkward shape.
__________________
Home Cinema - Sky HD, Panasonic DMP-BDT210, Denon AVR 2808 (Pre amp into MF A3.2 Amp), Monitor Audio Silver S8, MA RS Silver LCR, 4x Q Acoustics 1010 + sub, Mitsubishi HC7000 HD Projector
Stereo - PC/NAS (Synology DS212J), Squeezebox Touch via CAT6, MF A3.2 Amp, Monitor Audio Silver S8
RobinKidderminster
RobinKidderminster's picture
RE: My system
Dont we all have awkward room? Have u tried the centre brought forward to the front edge and fronts away a few inches? Cosy setup I recon. Thanks for de pix. Cheers
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1Base trap Project - http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-pro... treatment - click for pics : Room pix - Clicky : Old setup - Clicky
f1only
f1only's picture
RE: My system
Cheers guys.
The wood is solid oak.
I would bring the centre further forward BUT the stand it is sitting on is rather deep at 70cm & I would end up with my bi-wiring showing & no real way of hiding it neatly.
RobinKidderminster
RE: My system
Maybe try centre raised on feet? Im sure it will make no difference but dont we all enjoy a tweak. Best suggest is leave it alone and enjoy.  Smile
__________________
f1only
f1only's picture
RE: My system
Thank you for the suggestion, It is already raised on feet but only by about a cm. The only other option is put a shelf in above, I thought that may make it a bit messy too.
Regards
GSB
GSB's picture
RE: My system
Looking great f1only,i have oak furniture too,but my center is in the shelf of the tv stand Smile
__________________
PanasonicTX-P46GT30B..Yamaha RX-A1010...Music Fidelity M3i...OPPO105EU...KEFR100/R200C/3001SE/HTB2SE...SkyHD2TB...QED Copper Speaker Cable /HDMI/Analogue...PS3...IPAD2
steve_1979
steve_1979's picture
RE: My system
Nice looking setup. Smile
How do the speakers sound jammed up into the corners like that?
__________________
PC > AVI Neutron Five 2.1
f1only
f1only's picture
RE: My system
They dont sound bad, all are front ported & are about 6 inches away from the wall & bookcase.
f1only
f1only's picture
RE: My system
Hi Robin, I have now had a little time to reflect on your comment.
I have now come to the conclusion that i will try to get a floating shelf with a cable tidy built in for the Centre speaker. This should to raise it enough to put my Tivo box underneath. I recon that this will help to tidy the area up a bit & improve on the centre speakers soundstage with it being more in line with the front Left & Right floor standers woofers.
Question is can i get either a wooden one & use a cheap cable tidy to go with? it or a glass one? It needs to be around 30cm deep & 55 cm long to fit my centre speaker on.
Regards ... Paul
RobinKidderminster
RE: My system
I presume by floating shelf you mean a wall hung shelf. Brackets could be hidden behind the tv or box but I dont understand how this would bring the front closer in line with fronts. I would look for a slim open backed box matching the stand maybe?? Good luck
__________________
f1only
f1only's picture
RE: My system
Good suggestion I did not think of that. I might get one made up to house it all, thankyou for that..
Best Regards ,, Paul
f1only
f1only's picture
RE: My system
Well after that suggestion i have upgraded slightly & added a new bespoke stand/ plinth for my centre speaker.  This has enabled me to tidy up the look with the Virgin tivo box too. All in Oak the same as the rest of it.
Updated
I am now considering re-doing the whole lot with one bespoke stand, when finances allow of course, as i'm after a new A/V Amp later on in the year .
RobinKidderminster
RE: My system
I rather like the plynth. I am not really sure how much the position makes, I have often tweaked but since my centre is a closwd box, I think position is less critical. Finding an off the shelf cabinet to house a centre is hard. Solid oak? The bizz! Is it all sounding good? Cheers
__________________
