My System
20 replies [Last post]
Tonestar1
Tonestar1's picture
my system
Tonestar1
Tonestar1's picture
Re: My System
Tonestar1
Tonestar1's picture
Re: My System
GRRR il get there soon
Tonestar1
Tonestar1's picture
Re: My System
I've tried adding the images but can't get it to work, so if you want see it have a look here
http://s739.photobucket.com/albums/xx32/tonycraig/
D.J.KRIME
D.J.KRIME's picture
Re: My System
Could not get your other images to give me a usible URL
__________________
My usefull posts Laughing How To Calibrate Your TV
daveh75
daveh75's picture
Re: My System
Here's the rest.......
__________________
PJPro
PJPro's picture
Re: My System
Take a look at this thread which shows you how to post images.
__________________
My useful(?) What HiFi Forum threads can be found here.
Tonestar1
Tonestar1's picture
Re: My System
Thanks guys
I had previously tried to upload using the tree image above where i'm typing just now. Not sure if it's an issue with Safari or if im just incompetent.  I read your post and i'm now more comfortable using code.  See Laughing out loud (hope this works)
<img src="http://ec.mashable.com/wp-content/uploads/2007/12/radiohead-in-rainbows.png"/>
Tonestar1
Tonestar1's picture
Re: My System
<img src="http://i.zdnet.com/blogs/radiohead_in_rainbows2.jpg" width="400"/>
<img src="radiohead_in_rainbows2.jpg" width="400"/>
<img src="http://2.bp.blogspot.com/_3nNkcQ1t7hM/R8_BvpMm-9I/AAAAAAAAC5M/adTFpELNr5E/s1600-h/radiohead.hail.to.the.thief_2.jpg" width"400"/>
Hi can anyone tell me what i'm doing wrong here?
daveh75
daveh75's picture
Re: My System
If PJP's posting tutorial doesn't work for you(it doesn't for me) ,then on the toolbar above where you type your reply,there should an "insert/edit image" button(looks like a tree) if you click on that,you'll get a pop-up box appear, you then copy your image url into the "image url" field at the top of the pop-up box then click on the "insert" at the bottom your image will appear.
EDIT-ooops just noticed your post above...
__________________
Tonestar1
Tonestar1's picture
Re: My System
Cheers Dave,
I had been trying that on Saturday but couldn't get that to work either. I'm now trying via Firefox to see if that helps.
<img src="http://www.artsjournal.com/aboutlastnight/dylan.jpg" width="400"/>
Tonestar1
Tonestar1's picture
Re: My System
Dylan
Works fine using the tree in firefox.
Cheers Dave
daveh75
daveh75's picture
Re: My System
Tonestar1:
Cheers Dave,
It works on firefox for me using the insert button,,,
__________________
PJPro
PJPro's picture
Re: My System
daveh75:
If PJP's posting tutorial doesn't work for you(it doesn't for me)....
Doesn't it? It should do.....it's just simple html. Perhaps there's something I'm not explaining correctly?
I've copied Tonestar1's link and pasted it below eg this one
The fact that I can read the link in Tonestar1's post above tells me that Tonestar1 is not using the actual "less than" and "greater than" characters to surround the image element when he does his posting. He is using the entities which allow you to display the "less than" and "greater than" character in a web page.
If you type in the text below into your message you'll get the image above. Promise.
__________________
Tonestar1
Tonestar1's picture
Re: My System
copied and pasted from PJ as suggested above
My version using Apple < > signs. I thought ascii was just ascii
PJPro
PJPro's picture
Re: My System
Nope.
Are you actually hitting the less than and greater than keys? Cos when I look at the page source, I can see that you haven't actually typed in less than, you've actually typed in &lt;
__________________
