My old kit speakers
6 replies [Last post]
john dolan
john dolan's picture
Had a play with my old IPL A2 kit speakers while i was amp swapping the other day  http://dik.dolan.googlepages.com/IPLA2.jpg  id forgoten how good they sound and prefer them to the PMC.I built these maybe 25 years ago and ran them fully active for many years before converting them to passive.I made them with 18mm mdf layer glued to a 12mm mdf layer then 2 mm ply and the drivers are aerogel main and seas tweeters.
ElectroMan
ElectroMan's picture
Re: My old kit speakers
They look great.
You could not have made as much mess as I did, building a pair of transmission line speakers about 30 years ago ... in my bedroom!
I'll put some pictures up shortly ...Smile
john dolan
Heres my IPL transmission line kit  http://dik.dolan.googlepages.com/ipls3.JPG  but using my PMC speakers atm  http://dik.dolan.googlepages.com/wadamp1.JPG
the record spot
the record spot's picture
Hi John, not sure if anyone's mentioned yet, but those CDs don;t tend to do so well on turntables - try it in your Cyrus player instead! Wink
Seriously, that's a stonkingly good system - is there any chance you post up a few more shots of the 401 when you get a chance?
__________________
Onkyo TX-8050 / Tannoy Revolution DC4 / Marantz SA7001-KI / Apple TV 3 / Sony PS3 320Gb / Denon DVD-3930
john dolan
the record spot
Nice one - very impressive deck; the piano black plinth's rather smart too.
__________________
john dolan
I made the plinth when i got the garrard around 25 years ago.From memory i used 8 sheets of 18mm mdf each one cut to fit the turntable like a glove.I sprayed the plinth with a airgun and used a ford transit wheel as air source.After maybe 10 coats of paint and much sanding it then was sprayed with lacquer.Arm is a rewired rega rb300 with a michell tecno weight.With a good record it beats the cyrus cd player with ease.
