Loudspeaker upgrade
Fri, Dec 7 2012, 1:08PM
Hi all i need help with a loudspeaker upfgrade currently im using a system consisting of cyrus cd xtse + cd transport this is connected to my naim dac which is then connected to my naim nac 202 /200 pre /power amp the loudspeakers are dynaudio contour 1.1 i also connect my laptop to my naim dac via a musical fidelity vlink usb- spidf converter the system is great but wondered if better speakers around 2000.00 or a bit more would bring greater clarity i am using napsc power supply on naim preamp speaker cable is chord odyssey 2
Sat, Dec 8 2012, 5:00PM
#2
Hi Audiodave42 I would dem the kef r500 and the kef r700 these are realy great speakers if you have the room for them what music do you listen to
Hi audiodave 42
nice set-up you have ive the same amps as you
you really must try the kef ls50 speakers they sound awesome in my system and think you might be suprised to here how great they will sound in yours
ive never heard any dynaudio speakers before but from my understanding are genrally quite bassy so if your still after a speaker with plenty of bass then maybe you should look at at the dynaudio range.
but for me and most kef ls50 users they are fantastic sounding speakers from bass to midrange upto the highs.
not to mention how great they look
p.s try posting this question in the hifi forum you'll get a better response from other members
regards
80s boy
Naim 202/200 pre/power Amp - Kef LS50 Speakers -
Rega Dac - Spotify Premium.
