Expert help needed...apply within!!
5 replies [Last post]
RG550
RG550's picture
Hello everyone,
First off, Happy New Year!!
Secondly, I have been saving for quite a while now so that I can replace my old CRT TV and DVD Player.
I have just purchased the following equipment from the What HIFI Awards:
TV - LG 42LH5000
Speakers - Q Acoustics 2000 Cinema Pack
Amplifier -  Sony STR-DH800
and a PS3 Slim.
I was wondering if anyone could offer advise on speaker stands and a seperate stand for the TV, amp and PS3. Should I go for the Q Acoustics matching speaker stands? They look sturdy and are resonably priced. Is there a good quality stand to hold the tv, amp, centre speaker box and PS3?
Also, i'm not sure about cables? Is it wise to buy items from the Awards list  (eg - Chord Company HDMI SuperShield)?
 Thankyou very much for taking the time to read my post, any help/advise would be more than welcome!!
 Russ
Messiah
Messiah's picture
Re: Expert help needed...apply within!!
Personally I have THIS stand and it is great for the price!
These stands? They certainly look up to the job. As with anything though, maybe you can demo them compared to others to see if there is any noticeable difference....
As far as the cabling is concerned then I guess it depends on budget. For speaker cable, THIS is very well regarded. However, if this is a bit too expensive then you could use something like THIS.
For HDMI the Supershield is another well reviewed cable. However there are always debates over the improvements more expensive HDMI cables make. I would suggest trying a couple at various price points and see what one is best for you. THIS has to be a good place to start.
__________________
System Photos | Netbook (iTunes) | Onkyo ND-S1 | AVI ADM 9.1 | Yamaha Sub | Epoz Aktimate Mini
RG550
RG550's picture
Thankyou very much for all of your help Messiah!!
One quick question if you don't mind, will I be able to make full use of the speakers and amp I listed from the PS3? Would you recommend a seperate BluRay Player?
Many thanks again,
Russ
Messiah
Messiah's picture
The PS3 will be fine with your set up. I am quite happy with mine....
Whether you would benefit from a separate BD player is really for you to determine. Once everything is in place I would use the PS3 for a while and then see if you can demo another BD player to see if there is any benefit in the upgrade.
__________________
bigboss
bigboss's picture
With regards to HDMI cables, this thread should help you: http://community.whathifi.com/forums/t/363271.aspx
__________________
RG550
RG550's picture
Thankyou very much Smile!!
