dm38dab speakers
3 replies [Last post]
martin38
martin38's picture
hI i have a denon dm38dab with 9.1 diamond sound is not to my taste have to turn treble up to max to achieve a so called crisp noise also to much base need to change these speakers many people have recommended dali zensor 1 is the even a better speaker that will match to the little denon???? upto 300 pounds?? or do i just by a decent amp marantz maybe all i want is a clear precice sound with gentle base can anyone help please  regards Martin.........
drichardb
drichardb's picture
RE: dm38dab speakers
Hi Martin38,
This section of the forum is for showing off your system Cool
You might want to make a post in the HiFi section to get the right people looking at it. Smile
__________________
My Setup
chebby
chebby's picture
If you need to turn the treble up to the maximum with Diamond 9.1s - to match your taste for 'crispness' - then it is likely you will have to do the same with any speaker.  The 9.1s (according to the WHF review) are already clear and detailed.
Sounds like...
(a) there is something faulty like blown tweeters.
(b) you simply prefer an awful lot of 'crisp'.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Apple iPad Mini • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
martin38
martin38's picture
Sounds like...
thanks very much bought speakers off ebay maybe they are faulty
