10 posts / 0 new
Last post
Eyre200366's picture
Last seen: 1 year 3 days ago
Connecting an AV Receiver to a Sky Box
I am new to What Hifi and have a problem with my system. My equipment consists of a Samsung Smart TV UE32F5500, Sky HD Box and a Pioneer AV Receiver VSX S300 and can only connect the Pioneer Receiver to the Sky Box via the television as there is only one HDMI port on the back of theSky box and although i have tried a splitter it didnt work as presumably you cant split the signal. Anyone got any ideas?
Roger Iain Mason
his dudeness's picture
Last seen: 2 weeks 16 hours ago
RE: Connecting an AV Receiver to a Sky Box
you connect your sky box via hdmi to a hdmi input on the pioneer,and then a hdmi cable from the hdmi output on the pioneer to hdmi in on your tv,there should be a hdmi input on the pioneer marked sat,set receiver to that input.
lg55b6v oled,oppo uhd203,sr7008,tannoydc6tse,dc6,d6lcr,dc6,svs sb2000,humax hdr1000s,synology ds213j,nexus 5&7
RobinKidderminster's picture
Last seen: 3 months 3 weeks ago
Clearly correct dude but does the OP want to use the tv/sky box when the amp is off? I use the aerial socket for the tv daytime and hdmi as described when using the amp. You could use scart or other in the same way. Some splitters (often powered) will work but not simple cheap ones. If others cant help ask Maplins or Currys etc and re5urn it if it doesnt work. I had one which worked (still unsold on Amazon I think) but chose the other option to save on box count.
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
The_Lhc's picture
Last seen: 4 months 1 week ago
The easiest thing would be to take the HDMI from the Sky straight to the TV and an optical connection from Sky to the amp, that way you'll get proper surround when you want it and can still use the TV speakers if you don't want the amp on.
yea optical will work lovely,the amp also supports pass through in standby
Shoot.  :oops: LHC is right. My setup is as described because I use a BD player too.
The_Lhc's picture
You could trying sounding a little LESS surprised!  |(
Do i still need an HDMI cable from the TV to the Amplifier though?
Roger Iain Mason
Paul.'s picture
Last seen: 2 days 4 hours ago
Edit: sorry, didnt read it properly  :wall:
spiny norman's picture
Last seen: 20 hours 24 min ago
If you follow The_Lhc's suggestion
and you don't have any other components (eg Blu-ray, games console, etc) connected via HDMI to the receiver, then no, you don't.
Mind you, you might want to run an HDMI from the TV to the receiver so you can get sound back from the telly to the Pioneer using the Audio Return Channel feature (eg when watching programmes from the TV tuner rather than the Sky box), and the Pioneer does also have standby passthrough, so an incoming HDMI signal will be passed to the TV even when the receiver is in standby.
So really you could use either the Sky box -> HDMI -> receiver -> HDMI -> TV route, or the Sky box -> HDMI -> TV, Sky box -> optical digital -> receiver one. The cable cost will be about the same, and the performance will be, too.
And so, on Feb 22nd 1966,...
Log in to post comments
