WIFI printing
7 replies [Last post]
gsyx123
gsyx123's picture
Hi Guys, i've just upgraded my old printer to a Canon Pixma 970 networkable colour printer. i have a bt home hub in my lounge and a desktop computer upstairs with this printer. My desktop is made WIFI  by the addition of a Dell truemobile router, My question is this: can anyone suggest a reliable method of making the printer work thru wifi without having the computer switched on? this would enable me to print from my laptop.
Thanx in advance
__________________
Pioneer KRP-500A,Pioneer VSX-LX55,Pioneer BDP-LX52,KEF KHT3005SE Speakers,SkyHD 1tb,Sony PS3,WII console,Alienware M18x,IPad 64gb wifi 3G,IPhone 4S
John Duncan
John Duncan's picture
Re: WIFI printing
Get a wireless print server. Airport Express is one, though there are cheaper (but they're only print servers, as opposed to the AX's other uses....)
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
Tarquinh
Tarquinh's picture
Re: WIFI printing
I'm not familiar with the router, but it includes a 4 port switch so you should be able to connect your printer directly to the router. Once you've run any setup instruction (see Dell support) you should be able to see it over the wireless network. Might take a bit of configuring, though.
John Duncan
Re: WIFI printing
Tarquinh:
Only if the printer's ethernet-enabled though, and don't they cost big bucks? Unless I misunderstand what you're getting at.
__________________
professorhat
professorhat's picture
Re: WIFI printing
"Canon Pixma 970 networkable colour printer" suggests it might have an ethernet port...
Tarquinh
Tarquinh's picture
Re: WIFI printing
Hi John,
Apparently it is, assuming its the MP970 and judging by the I material skimmed through. The Canon site has some FAQS here .
John Duncan
Re: WIFI printing
professorhat:
Are you saying I can't read? Hm? Hm?
(slaps forehead)
__________________
John Duncan
Re: WIFI printing
OK, OK, I've read it now. If the printer's nowhere near any of your routers/home hub etc, then my original advice still stands.......
__________________
