Wifi (Internet TV) on Samsung LE40B554
4 replies [Last post]
matm00
matm00's picture
Does anyone know if it's possible to buy a device to link up my Samsung LE40B554 to the internet, or is it only certain TVs that are able to do this? Thanks.
purley
purley's picture
Re: Wifi (Internet TV) on Samsung LE40B554
Hi.
You can buy a device from Q-waves, called "wireless usb av kit"amazon or maplin, for about £70-£80.It works fine, i have one
Paul.
matm00
matm00's picture
That's fantastic, thanks for that. I've had a look and it says you need a laptop or PC - is there anything similar that doesn't require this? Some of the newer Samsung TVs have something called internet@tv. With this I could stream directly from LoveFilm for example without the need of a computer...
landzw
landzw's picture
I own the LE40B554 and i wasn't aware you could connect it to the internet , i will check the paperwork out tonight as its never been mentioned in any review, Also there isn't a connection for the internet
__________________
My Cheap Cheerful Setup
LG 50PA650T , Sky HD , Sony BDPS185B , Xbox 360 , Sound Organisation AV Rack
Yamaha MCR-555 , Shuffle , Beyerdynamic DTX 71iE
landzw
landzw's picture
No i can't find anything
__________________
