wifi for all devices
7 replies [Last post]
balzo
balzo's picture
As a non techi I have not found a simple solution to my needs - to play all my audio/video wirelessly ie from mac, pc, ipod, iphone etc. I have apple TV which is a part solution. Is this simple a router issue? or am I missing a point?
 thanks
professorhat
professorhat's picture
Re: wifi for all devices
What exactly are you trying to achieve and what issues are you facing? The Apple TV will stream videos and music from iTunes installed on your Mac or PC. If it's a newer second gen Apple TV, you can stream music and video direct from your iPod Touch (2G or above) or iPhone (3G or above) to it as long as Touch / iPhone are running the latest iOS 4.2 software. Unfortunately the old first gen Apple TV doesn't allow this.
John Duncan
John Duncan's picture
Ooo I thought it did now (though it may have been a third-party hack).
EDIT - yep, it's a hack. (and probably isn't actually airplay, but something that imitates it)
__________________
Cambridge Audio StreamMagic 6  |  751BD  |  651A  |  PMC DB1i | A secret shiny box | Sonos Play:3
Moderator. mail: john.duncan.whf at the mail of g dot com
fayeanddavid
fayeanddavid's picture
professorhat:
professorhat
Please help me here also, am I right in thinking then that Apple tv (new gen) is the same thing as AE but with on demand video and vodeo playback from pc and mac devices as well as iTunes
And, is Apple tv the "better" purchase due to the above?
__________________
Lounge: Sony 52W5500, Yamaha RX V2700, Sony S390 BDP, Sky+ HD 1TB, KEF R500/R600C/T301 rears, Chord Odyssey and Carnival for rears, Chord ProDac/HDMI, Chord Power Chords,  BK Monolith DF
Family: Cambridge One, Rega P3-24 Elys 2, Mission 771e, Chord Carnival cable
Various: MacBook Pro, HP Pavilion dm4,  iPod docks,  iPhones, 160GB Classic and various generation Nanos
professorhat
JohnDuncan:
Useful to know - thanks, JD.
professorhat
fayeanddavid:
Kind of, though the Airport Express also offers some other functions like including a DAC, being able to create a wireless network (if necessary) and offers wireless printing by connecting a USB printer to its USB port.
fayeanddavid:
Depends on your needs. If just for streaming over an existing wireless network, then yes as you can also add video streaming to it. If you just want to stream music to a stereo amp without also having to buy a DAC, or want to have wireless printing etc. then the AE is a better bet.
fayeanddavid
Thanks prof
Spot on as ever!
__________________
edsib1
edsib1's picture
If ur kit (tv,bdplayer,amp,mediastreamer) is new it may well have dlna built-in -
then theres no need to buy extra kit like AppleTV, or Airport Express.
If ur really want to get into streaming video -for example dvd rips then - a proper mediaplayer like an Xstreamer, PlayonHD, or WDLive might be a better alternative than an AppleTV.
That way you dont get stuck with poor format support and video quality.
