The 1080p streaming stutter.
Hey
Fianlly got my AC Ryan/Playon HD all up and running yesterday, and tried out movies that were 1080p dts, but they stutter like mad, just like the PS3 did.
I am using 85mp homeplugs, with a normal sky+ router but I have a 13mb interet connection which is quite fast compaired to uk standards.
Are the homeplugs the problem, or the basic wrieless g router. or both.
do I need to upgrade to 200mb homeplugs and a better router?
Whats your thoughts.
I cant run a ethernet from downstairs to upstairs as this is not possible.
Thanks guys and gals
I have an external HDD but whats the point of having to update it all the time bring it upstairs add files and bring it back downstairs. material, kinda defeats the point of a streamer or popcorn hour dont you think?, if you can just use your tv or other things for this.
So been reading, sky say they have the right to kick you off the network if you use other routers, but with all the HD stuff being brodcast, why are they not allowing people to have other routers, or not providing people with N routers, or those who need it.
Silly if you ask me.
canada16:I have an external HDD but whats the point of having to update it all the time bring it upstairs add files and bring it back downstairs. material, kinda defeats the point of a streamer or popcorn hour dont you think?, if you can just use your tv or other things for this.
I use my homeplugs and router to transfer files from PC to external drive, so I never have to take it upstairs.
200 Meg homeplugs should work. But they are dependant on your house wiring
I thought as much, how long does it take you to get a large file to the hard drive? say 10gb
I might try homeplugs as well, from what I read the router really has nothing to do with it, its the connection from the pc upstairs to down.
So either way the external hdd or homeplug might be the way to go.
canada16:I thought as much, how long does it take you to get a large file to the hard drive? say 10gb
To transfer a 10gb file about 40 minutes, maybe half an hour.
Wow thats a while.
I might try the homeplugs first.
Thanks.
Homeplugs are really dependent on the wiring in your house. In my house I can access and play DVD perfectly over a homeplug 200 connection, blurays stutter. If you can borrow some from a friend at all to try out before buying that would be a good idea.
So even with 200mbs blu-rays still stutter?
I think the only way to get a blu-ray to play and not take 40 min to transfer and stutter is to buy a 32gb stick for 32.00 on amazon.
For me yes they do stutter (on a full bluray, no down conversion). Depending on your wiring you may be ok. Thing is you won't know until you try it out.
canada16:So even with 200mbs blu-rays still stutter?
What size files are you streaming?
A 32Gb sticks no good as they ONLY run on FAT 32 which has file size limits of 4gb (So the only way it would work would be to split it up into chunks)
If its a full size bluray, most connections would struggle with that file size
canada16:Wow thats a while.
Thanks.
All you need to do is burn your films, transfer before you go to bed and in the morning they will all be on your hard drive. Hardly an issue? And absolutely no stuttering. My PCH plays any film perfectly.
aliEnRIK:If its a full size bluray, most connections would struggle with that file size
unless you're running a wired network. I've streamed blurays to both of my HTPC setups concurrently without an issue.
I have been looking and some have said that they have not been able to stream 720p and 1080p stuff and they bought a 1gb homeplugs,and they said it works a dream, but others have said no it doesnt.
I think the only way then is to try the 1gb homeplugs or run a 40m ethernet from downstairs to up, but I really dont want to do that.
the file I am trying to stream is a 1080p DTS 11GB file.
Thanks guys
I use these
If you hunt around they may be cheaper - I got them for less at PC World of all places - think it was a mis-price but I didn't complain. They were a bit niggly at first streaming to the XBox but the new dahsboard update and their new firmware seemed to have sorted out any problems but there are some concerns still out there in forum land if you take a look. Obviously your wiring will have an issue but if you go Gigabit you need to make sure your patch cables are at least Cat5e and any switches, routers and network cards are capable of that speed or you will just bottleneck somewhere. As HD goes I've only played around with the sample trailer for Alexander from the M$ website but at 1080p it was faultless streaming.
Hope this helps,
Ben.
- Login to post comments
Both. 85mbps isn't really what you get. Same with your router. You are not allowed to use anything but the Netgear router that Sky give you. There is a workaround though - google at your peril. I use a Linksys N router with 200mbps home plugs. However, I also use the Popcorn Hour and have my films on an external drive connected to it. Streaming works fine but I don't need it.
Screen - Samsung UE46D8000. Sources - Dell Zino HD 410; Sky HD; Sony BDP S550; Wyred 4 Sound DAC1. Amps - Yamaha RX-A3010; SimAudio Moon I-3 RS. Speakers - Vienna Acoustics Mozart Grand; Vienna Acoustics Waltz Grand centre; Proficient Audio W690 rears; Monitor Audio RSW12. Cables - Van Damme Blue 4mm speaker cable; Townsend DCT300 and Atlas Voyager interconnects; Van den Hul Optocoupler.
